The Nano runs the decoder for about 7.5 x 24 hours.
An error appears as shown in the figure below.
Temperature, memory and CPU are all normal.
Generally the print shows up when the h264/h265 stream has certain invalid data and cannot be parsed. If your input stream is good and only observe it in long run, We would need to replicate the issue and check. Please help share steps so that we can try. Either gstreamer command or jetson_multimedia_api sample.
Thank you for your reply.
I can’t provide the program to you quickly.
The decoder has been integrated into the main program.
I’ll check if H264 / H265 is good first
