A end Point question
https://docs.nvidia.com/jetson/archives/r35.4.1/DeveloperGuide/text/SD/Communications/PcieEndpointMode.html
This part is so brief that I don’t know how to start. Is there a more detailed tutorial?
You need to download the kernel and apply the change in the kernel configuration.
This is a guide of how to download, build and install the kernel sources Kernel Customization — NVIDIA Jetson Linux Developer Guide 1 documentation
Before to compile the kernel make -C kernel you need to add the line CONFIG_STRICT_DEVMEM=n to Linux_for_Tegra/source/kernel/kernel-jammy-src/arch/arm/configs/tegra_defconfig file
Then you can continue with all the steps to install the kernel.
Manuel Leiva
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com
Website: www.ridgerun.com
Thanks a lot ! But I still have a question: While making the NX as the EP, and another device as RC. Which device’s kernel configuration should I change? EP or RC or both?
Please can you explain more about what is EP and RC?
Manuel Leiva
