I am kind of confused about the struct and some funcs surrounding it. I pulled the code from the header file. Following the func will be the question:
cudnnCreateAlgorithmPerformance(cudnnAlgorithmPerformance_t* algoPerf, int numberToCreate );
Is algoPerf suppored to be a pointer to an array?
cudnnSetAlgorithmPerformance(
cudnnAlgorithmPerformance_t algoPerf,
cudnnAlgorithmDescriptor_t algoDesc,
cudnnStatus_t status,
float time,
size_t memory );
This isn’t even in the documentation is the user supposed to use it, and if it needs to be set we should just set the vars to zero?
cudnnDestroyAlgorithmPerformance(
int numberToDestroy);
This one makes it even more confusing. I would say that algoPerf is an array, but the documentation lists it as below.
cudnnDestroyAlgorithmPerformance(cudnnAlgorithmPerformance_t algoPerf);
Thanks in advance
