T4 • DeepStream Version
5.1 • JetPack Version (valid for Jetson only) • TensorRT Version
7.2 • NVIDIA GPU Driver Version (valid for GPU only)
440 • Issue Type( questions, new requirements, bugs)
BUG • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing)
In my test, two of the 24 streams failed to play,.
The result is that all streams cannot be inferred,then the program exits.
I there was a glitch in one of the camera rtsp streams you would expect things to carry on running and not crash the whole app?
Seems the rtmp stream failed with error.We don’t have mechanism to skip rtmp error. Please check the code in bus_callback() function in /opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream_app/deepstream_app.c
If you want special handling with error message, you can write your own code to handle that.
I solved the program exit with the reconnection, but I found that bus_callback could not solve the problem of queue blocking .
For example:
When I have four streams running, one of them has a problem.
Batch size is set to 4.
Streammux will wait for the abnormal stream . But I want to skip the abnormal video stream, and the other three streams are running properly.
