Just making a note that I would like to have some way of graphically debug my applications.
I’m hoping others will ++ this and show nvidia there’s interest in this.
Personally I don’t care much for which IDE is used, but there seems to be previous interest in gdb + eclipse:
[url=“DSDP/DD/GDB - Eclipsepedia”]http://wiki.eclipse.org/DSDP/DD/GDB[/url]
[url=“Starship Traders Sandbox MMO”]Starship Traders Sandbox MMO
ddd --debugger cuda-gdb works just fine right now.
Because ddd requires X environment, I think you have more than one GPU card in order to use cuda-gdb.
Do you know any way to use cuda-gdb with an user interface (certainly using one GPU card)? I tried cuda-gdb in console, it is quite hard to put breakpoints.
Thank you.
If you want GUI you need X. One solution is to ssh into the machine with the -X flag and then you get the debugger displayed remotely. Another options is to use emacs for the job
That’s a good idea. Your solution about SSH with the -X flag is useful. However, I currently have only one PC (running Windows and Linux on dual boot), I will try your solution later.
Thank you very much.
cgdb -d /usr/local/cuda/bin/cuda-gdb, or replace gdb link with cuda-gdb and run the cuda program in eclipse…both work!
(of course you need another device not attached to X)
