A long wait time during boot when jetpack6.2.2 is flashed to the Orin
MobaXterm_COM5ProlificUSB-to-SerialCommPortCOM5_20260228_103248.txt (38.8 KB)
it will wait a long durning this.there is no phenomena like this when i use jetpack 5.1.5
The question seems to be related to the Jetson AGX Orin module and its behavior when using MobaXterm with a USB-to-Serial Comm Port. However, the provided text does not directly relate to the question.
Based on the context provided, I will try to answer the question by comparing the different Jetson modules and their characteristics.
The Jetson AGX Orin module is a powerful AI computing platform that comes in different variants, including the Jetson AGX Orin 32GB, Jetson AGX Orin 64GB, and Jetson AGX Orin Industrial. These modules differ in their memory capacity, AI compute performance, and power consumption.
When using MobaXterm with a USB-to-Serial Comm Port, the behavior of the Jetson AGX Orin module may vary depending on the specific module and the configuration used. However, without more information, it is difficult to determine the exact cause of the issue.
In general, the Jetson AGX Orin module is designed to work with a variety of software development kits (SDKs) and tools, including the NVIDIA JetPack SDK. The JetPack SDK provides a comprehensive set of tools and libraries for developing AI applications on the Jetson platform.
If you are experiencing issues with the Jetson AGX Orin module and MobaXterm, I recommend checking the following:
  1. Ensure that the Jetson AGX Orin module is properly configured and connected to the USB-to-Serial Comm Port.
  2. Verify that the MobaXterm software is properly installed and configured on your host computer.
  3. Check the documentation for the Jetson AGX Orin module and MobaXterm to ensure that you are using the correct settings and configuration.
  4. If you are using a different SDK or toolchain, ensure that it is compatible with the Jetson AGX Orin module.
In terms of the differences between the Jetson AGX Orin 32GB and 64GB modules, the main difference is the memory capacity. The Jetson AGX Orin 64GB module has twice the memory capacity of the 32GB module, which can be beneficial for applications that require large amounts of memory.
The Jetson AGX Orin Industrial module is designed for industrial applications and has a different set of features and specifications compared to the other two modules.
In summary, the Jetson AGX Orin module is a powerful AI computing platform that comes in different variants, each with its own set of characteristics and features. When using MobaXterm with a USB-to-Serial Comm Port, the behavior of the module may vary depending on the specific module and configuration used.
Does the system experience the long boot time only on the first boot after flashing, or does it occur on every regular boot as well?
it occurs on every regular boot
For configuration changes:Set EEPROM evb_size to 0, and enabled PCIe EP configuration. No modifications were made to the official package.
Only the kernel was compiled, and pcie-epf.ko was copied to the rootfs before flashing.
A self-developed board was used without any new custom IP; only one UART serial port and one Ethernet port were retained.
