I was doing a test render, and i noticed noise on the render I’m using path traced, it was not like that the other day when I render it was clean, now it’s a lot of Noise, what can do to change that
It looks like the Optix Denoiser isn’t running. This can happen if you run out of VRam sometimes. Is there an error message in the console? What GPU are you using?
i have Intel(R) core™ i5-3570k CPU @ 3.40GHz NVidia GeForce RTX 2060 i’m about to check to see if i got a error
2021-04-19 13:40:54 [Error] [omni.usd] TF_PYTHON_EXCEPTION (secondary thread): in TfPyConvertPythonExceptionToTfErrors at line 114 of E:\w\ca6c508eae419cf8\USD\pxr\base\tf\pyError.cpp – Tf Python Exception
2021-04-19 13:40:54 [Warning] [omni.client.plugin] : usd_plugin: Tf Python Exception
it crash on me when i drag the model in the scene
2060 has limited amount of VRAM (6GB), which is why we recommend a higher GPU spec. I’m guessing that you have an error earlier in the log about the “Optix Denoiser”.
Unfortunately, although Create will run on a 2060 (some have used it to produce work for the Marbles Contest), reasonably complex scenes are likely to blow out the 6GB pretty quickly.
I understand i’m trying to buy the 2060 ti but can’t find it no where everything is sold out will that work
will a NVIDIA GeForce RTX 3060 Ti 8GB GDDR6 PCI Express 4.0 Graphics Card work for this
That will be better. The extra 2GB of VRAM will make a big difference. If you can get an RTX GPU with more than that, that would be even better since it’s easy to make complex scenes that use up all that memory.
what rtx graphic card would be better than the rtx 3060 it with price range 400-600
