How to pass a pointer to a function in the kernel. To then call this function from the kernel?
This SO question/answer links to a number of related examples:
also there was this recent thread on this forum:
typedef double (* FType) (float x);
global void method () {
int i = blockDim.x * blockIdx.x + threadIdx.x;
//how to call this function here??
F (i);
void main (void *Function) {
Ftype F=(Ftype)(Function);
method <<< 1,1 >>> ();
template and device-lambda make it easy.
/* devfun.cu:
* nvcc --expt-extended-lambda devfun.cu
#include <cuda_runtime.h>
#include <device_launch_parameters.h>
#include <stdio.h>
__device__ void dev_print(int i) {
printf("print(%d)\n", i);
template<typename Fun>
__global__ void kernel(Fun f) {
f(threadIdx.x);
int main() {
auto device_fun = [] __device__ (int i) { dev_print(i); };
kernel<<<1,5>>>(device_fun);
I’m in the main () function is a pointer to a function in a C # project. And I need to transfer to your device
__global__ void method () {
F (i);
you wanna call host-function on device?
Yes
you can NOT.
take a look cudaStreamAddCallback() API that can call host-function BETWEEN kernel-calls.
