When i run deepstream-test5-app,The RTSP video blinks every 1 to 2 seconds and the following error occurs with each blinks:
ERROR from src_elem0: Could not read from resource.
Debug info: gstrtspsrc.c(5216): gst_rtspsrc_loop_interleaved (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstRTSPSrc:src_elem0:
Could not receive message. (Parse error)
ERROR from src_elem0: Internal data stream error.
Debug info: gstrtspsrc.c(5653): gst_rtspsrc_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstRTSPSrc:src_elem0:
streaming stopped, reason error (-5)
Reset source pipeline reset_source_pipeline 0x7f7c1e0080
The program crashes after several blinks.
I compiled deepstream-test5 and ran the following command:
./deepstream-test5-app -c configs/test5_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt -p 0
The complete error is as follows:
Using winsys: x11
Creating LL OSD context new
0:00:00.798397027 16110 0x55955948d0 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 6]:useEngineFile(): Failed to read from model engine file
0:00:00.798466915 16110 0x55955948d0 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 6]:initialize(): Trying to create engine from model files
0:00:00.798631620 16110 0x55955948d0 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 6]:generateTRTModel(): INT8 not supported by platform. Trying FP16 mode.
Warning: Flatten layer ignored. TensorRT implicitly flattens input to FullyConnected layers, but in other circumstances this will result in undefined behavior.
0:01:06.287058986 16110 0x55955948d0 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 6]:generateTRTModel(): Storing the serialized cuda engine to file at /opt/nvidia/deepstream/deepstream-4.0/samples/models/Secondary_CarMake/resnet18.caffemodel_b16_fp16.engine
0:01:06.397680516 16110 0x55955948d0 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 5]:useEngineFile(): Failed to read from model engine file
0:01:06.397734564 16110 0x55955948d0 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 5]:initialize(): Trying to create engine from model files
0:01:06.397841348 16110 0x55955948d0 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 5]:generateTRTModel(): INT8 not supported by platform. Trying FP16 mode.
0:02:07.233649928 16110 0x55955948d0 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 5]:generateTRTModel(): Storing the serialized cuda engine to file at /opt/nvidia/deepstream/deepstream-4.0/samples/models/Secondary_CarColor/resnet18.caffemodel_b16_fp16.engine
0:02:07.302645265 16110 0x55955948d0 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 4]:useEngineFile(): Failed to read from model engine file
0:02:07.302699729 16110 0x55955948d0 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 4]:initialize(): Trying to create engine from model files
0:02:07.302825554 16110 0x55955948d0 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 4]:generateTRTModel(): INT8 not supported by platform. Trying FP16 mode.
0:03:06.541424653 16110 0x55955948d0 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 4]:generateTRTModel(): Storing the serialized cuda engine to file at /opt/nvidia/deepstream/deepstream-4.0/samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_fp16.engine
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_klt.so
gstnvtracker: Optional NvMOT_RemoveStreams not implemented
gstnvtracker: Batch processing is OFF
0:03:06.721991949 16110 0x55955948d0 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:useEngineFile(): Failed to read from model engine file
0:03:06.722112173 16110 0x55955948d0 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:initialize(): Trying to create engine from model files
0:03:06.722231629 16110 0x55955948d0 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:generateTRTModel(): INT8 not supported by platform. Trying FP16 mode.
0:03:48.372441958 16110 0x55955948d0 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:generateTRTModel(): Storing the serialized cuda engine to file at /opt/nvidia/deepstream/deepstream-4.0/samples/models/Primary_Detector/resnet10.caffemodel_b2_fp16.engine
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
**PERF: FPS 0 (Avg) FPS 1 (Avg)
**PERF: 0.00 (0.00) 0.00 (0.00)
** INFO: <bus_callback:189>: Pipeline ready
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
** INFO: <bus_callback:175>: Pipeline running
KLT Tracker Init
KLT Tracker Init
,ERROR from src_elem0: Could not read from resource.
** WARN: <bbox_generated_probe_after_analytics:554>: Source 0: NTP timestamps are backward in time. Current: 0 previous: 1960000000
**PERF: 20.48 (20.48) 25.24 (25.24)
** WARN: <bbox_generated_probe_after_analytics:554>: Source 0: NTP timestamps are backward in time. Current: 0 previous: 5721000000
**PERF: 21.70 (21.13) 25.43 (25.34)
**PERF: 18.98 (20.39) 24.98 (25.22)
ERROR from decodebin_elem0: GStreamer encountered a general stream error.
Debug info: gstdecodebin2.c(4695): gst_decode_bin_expose (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstDecodeBin:decodebin_elem0:
all streams without buffers
Quitting
App run failed
I changed the configuration file as follows:
[source0]
uri=rtsp://admin:1111@10.0.0.155:554
[sink1]
msg-broker-conn-str=39.97.109.63;9092;deepstream-data
topic=deepstream-data
