A problem deepstream4.0 link rtsp
When I use deepstream link rtsp,it occur error like:
Creating LL OSD context new
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_klt.so
gstnvtracker: Optional NvMOT_RemoveStreams not implemented
gstnvtracker: Batch processing is OFF
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
** INFO: <bus_callback:163>: Pipeline ready
**PERF: FPS 0 (Avg)
**PERF: 0.00 (0.00)
** ERROR: <cb_newpad3:396>: Failed to link depay loader to rtsp src
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
** INFO: <bus_callback:149>: Pipeline running
gstnvtracker: NvBufSurfTransform failed with error -2 while converting buffergstnvtracker: Failed to convert input batch.
ERROR from tracking_tracker: Failed to submit input to tracker
0:00:05.451222693 5334 0x20e3e450 WARN nvinfer gstnvinfer.cpp:1830:gst_nvinfer_output_loop:<primary_gie_classifier> error: Internal data stream error.
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvtracker2/gstnvtracker.cpp(511): gst_nv_tracker_submit_input_buffer (): /GstPipeline:pipeline/GstBin:tracking_bin/GstNvTracker:tracking_tracker
0:00:05.451331762 5334 0x20e3e450 WARN nvinfer gstnvinfer.cpp:1830:gst_nvinfer_output_loop:<primary_gie_classifier> error: streaming stopped, reason error (-5)
ERROR from primary_gie_classifier: Internal data stream error.
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(1830): gst_nvinfer_output_loop (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie_classifier:
Quitting
App run failed
I use the configfile which is source12_1080p_dec_infer-resnet_tracker_tiled_display_fp16_tx2.txt.I only modifer it like:
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=4
uri=rtsp://admin:1111@10.0.0.155:554
#uri=file://../../streams/sample_1080p_h264.mp4
num-sources=1
#drop-frame-interval=2
gpu-id=0
(0): memtype_device - Memory type Device
(1): memtype_pinned - Memory type Host Pinned
(2): memtype_unified - Memory type Unified
cudadec-memtype=0
And I use a camera of Tiandy brand.
When I set [tiled-display] enable=0 and [tracker] enable=0,it can work but the bound box twinkle.
Please upgrade to DS4.0.1 and try again.
