Hi all,
I have a code developed under win10 and it works well. There is a fortran-calling-c in it. The cuda c file is simple:
exts.cu:
#include <thrust/device_vector.h>
#include <thrust/copy.h>
#include <thrust/sort.h>
extern “C”
void thr_SbyK( int *KEY, int N, int *ARRAY)
thrust::device_ptr dev_ptr1(KEY);
thrust::device_ptr dev_ptr2(ARRAY);
thrust::sort_by_key(dev_ptr1, dev_ptr1+N, dev_ptr2);
The relative code in makefile is:
CUDAFLAGS = -Mcuda=cc60
INCCO=“C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\ucrt”
INCCU=“C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v8.0\include”
nvcc -I$(INCCO) -I$(INCCU) -arch sm_61 -c exts.cu
Today I try to compile it in linux system. I changed its relative code in makefile as:
INCCU="/opt/cuda-9.0/lib64"
nvcc -I$(INCCU) -arch sm_61 -c -lstdc++ exts.cu
It turns out that this file exts.cu is compiled succesfully, but when I try to link them with:
pgfortran $(CUDAFLAGS) $(F90FLAGS) -o sphcf.$(EXE) sphmod.$(OBJ) kersph.$(OBJ) initsph.$(OBJ) divide.$(OBJ) exts.$(OBJ) singlestep.$(OBJ) output.$(OBJ) main.$(OBJ) $<
it shows an error as:
/usr/bin/ld: exts.o: undefined reference to symbol ‘_ZNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEaSEPKc@@GLIBCXX_3.4.21’
//usr/lib/x86_64-linux-gnu/libstdc++.so.6: error adding symbols: DSO missing from command line
How can I solve this?
Thanks a lot!
