A problem in yolov4 from nano
Hi,During yolov4 training with (TAO), the trained(.etlt )file cannot be combined with tensorrt for acceleration.
we use jetpack 4.4 tensorrt 7.1.3
[WARNING] onnx2trt_utils.cpp:220: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[WARNING] onnx2trt_utils.cpp:246: One or more weights outside the range of INT32 was clamped
[INFO] ModelImporter.cpp:135: No importer registered for op: BatchedNMSDynamic_TRT. Attempting to import as plugin.
[INFO] builtin_op_importers.cpp:3659: Searching for plugin: BatchedNMSDynamic_TRT, plugin_version: 1, plugin_namespace:
[ERROR] INVALID_ARGUMENT: getPluginCreator could not find plugin BatchedNMSDynamic_TRT version 1
ERROR: builtin_op_importers.cpp:3661 In function importFallbackPluginImporter:
[8] Assertion failed: creator && “Plugin not found, are the plugin name, version, and namespace correct?”
[ERROR] Failed to parse the model, please check the encoding key to make sure it’s correct
[INFO] Detected input dimensions from the model: (-1, 3, 384, 1248)
[INFO] Model has dynamic shape. Setting up optimization profiles.
[INFO] Using optimization profile min shape: (1, 3, 384, 1248) for input: Input
[INFO] Using optimization profile opt shape: (8, 3, 384, 1248) for input: Input
[INFO] Using optimization profile max shape: (16, 3, 384, 1248) for input: Input
[ERROR] Network must have at least one output
[ERROR] Network validation failed.
[ERROR] Unable to create engine
The error indicates a missing plugin implementation.
Would you mind testing this on a JetPack 4.5.1 environment?
