Hi all,
I built my CUDA code into a DLL and call it from LabVIEW, the strange thing I found is once I run my EXE, the CUDA would append the LabVIEW.exe to one of the core of my dual core machine… See the attach picture (the ‘CPU 1’ is unchecked):
This would make the LabVIEW.exe only runs on one of the cores letting the second core idling, I am not sure whether this is the expected behaviour or do you have any suggestion to make the second core run in parallel with GPU.
Thanks a lot.
