When I moved to the part ‘Building From Source On Jetson’ and the step ‘Configuring with CMake’, after I entered the code ‘cmake …/’, there seems to have a connection problem.The results are pasted below:
Does “host nvidia.app.box.com” find an associated dotted-decimal IP address? This should show something like:
# host nvidia.app.box.com
nvidia.app.box.com is an alias for wildcard.app.box.com.
wildcard.app.box.com has address 107.152.24.199
wildcard.app.box.com has address 107.152.25.199
Next, does ping see the dotted-decimal address (“ping 107.152.24.199”)?
When you get there it wants a password. If you get that far, then it might be that your application is working fine, but the password prompt wasn’t offered. I’m not sure how your application works with password requests.
NOTE: I tried logging in, apparently it needs a different login than forums.
Firstly, I do not have the result like you. At most time,it shows "connection timed out"like i quoted in the question, and at the rest of time, I got such result:
--2018-03-07 01:42:21-- https://nvidia.box.com/shared/static/5z3l76p8ap4n0o6rk7lyasdog9f14gc7.prototxt
Resolving nvidia.box.com (nvidia.box.com)... 107.152.24.197
Connecting to nvidia.box.com (nvidia.box.com)|107.152.24.197|:443... connected.
WARNING: cannot verify nvidia.box.com's certificate, issued by ‘CN=GeoTrust SSL CA - G3,O=GeoTrust Inc.,C=US’:
Unable to locally verify the issuer's authority.
HTTP request sent, awaiting response... 301 Moved Permanently
Location: https://nvidia.app.box.com/shared/static/5z3l76p8ap4n0o6rk7lyasdog9f14gc7.prototxt [following]
Now, I have set a VPN so that I can access nvidia.app.box.com via browser. However, using the command “wget” to download files from nvidia.app.box.com still does not work. It shows that “connection timed out”.
The reason of this problem is that China block the access to nvidia.app.box.com.
Here is my way to solve this problem.
I use LANTERN to access this website on my host PC, therefore, I can wget files. However, LANTERN is not supported on TX1 because its core is arm64 and LANTERN also works on amd64. Then, I use HTTP PROXY on TX1 to access nvidia.app.box.com. It does work when I access to the website on browser, but not in the terminal. Finally, I download all files at host PC and copy them to TX1.
Thanks again for your help! I am very grateful that we have such a energetic forum to solve my problem!
I am also a Chinese user, you can modify the file CMakePreBuild. sh. Remove the code to download and uncompress the Caffe network model. In addition, the Caffe network model, I put it on the Baidu network disk. You can go download. After the download is complete, you need to extract the decompression, and then put them in the /jetson-inference/data/networks path.
Baidu networkd disk link:https://pan.baidu.com/share/init?surl=6rFmIRMzvcrskiaPonnOtQ
Password:rtr4
