I just indtalled PGI 19.4 community edition, together with the VS 2017 community edition and the Intel MKL libs in Windows 10 1903 edition. I encounterd two problems.
(1) I am trying to compile my program with intel MKL vml functions such as vderf. The compile command is pgfortran -o test.exe myprog1.f90 mkl_intel_lp64.lib mkl_pgi_thread.lib mkl_core.lib -mp. Then a problem comes out that “vderf” can’t be found. I am sure the lib directory is contained. While using ifort (ifort -o test.exe myprog1.f90 mkl_intel_lp64.lib mkl_intel_thread.lib mkl_core.lib libiomp5md.lib), there is no problem. Does pgi not surport MKL vml libs? I tried dfti in intel MKL using pgfortran, it works well, but not for vml function.
(2) I am trying to make a dll for another program. The exact example in “PGI Compiler User’s Guide” was used: pgfortran -Bdynamic -c object1.f, pgfortran -Mmakedll object1.obj -o obj1.dll, pgfortran -Bdynamic -o prog1 prog1.f -defaultlib:obj1. The firs two steps works well, but in the last step no file is created and no error or warnning is provided.
Can you point out my problem? Thanks a lot! They troubled me several days.
