A single isx031 can produce a picture, but two isx031 cannot produce a picture
Hi All,
A single isx031 can produce a picture, but two isx031 cannot produce a picture. Please help me find out the reason?
v4l2-ctl -d /dev/video0  --set-ctrl sensor_mode=1 --set-fmt-video=width=1920,height=1536 --stream-mmap --stream-to-host 192.168.1.111
root@tegra:/home/robot# sudo su
root@tegra:/home/robot# cd /sys/kernel/debug/dynamic_debug/
root@tegra:/sys/kernel/debug/dynamic_debug# echo file csi5_fops.c +p > control
root@tegra:/sys/kernel/debug/dynamic_debug# echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
root@tegra:/sys/kernel/debug/dynamic_debug# echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
root@tegra:/sys/kernel/debug/dynamic_debug# echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
root@tegra:/sys/kernel/debug/dynamic_debug# echo 1 > /sys/kernel/debug/bpmp/debug/clk/emc/mrq_rate_locked
root@tegra:/sys/kernel/debug/dynamic_debug# cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
832000000
root@tegra:/sys/kernel/debug/dynamic_debug# cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/isp/rate
1011200000
root@tegra:/sys/kernel/debug/dynamic_debug# cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
642900000
root@tegra:/sys/kernel/debug/dynamic_debug# cat /sys/kernel/debug/bpmp/debug/clk/emc/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/emc/rate
3199000000
root@tegra:/sys/kernel/debug/dynamic_debug# echo 1 > /sys/kernel/debug/tracing/tracing_on
root@tegra:/sys/kernel/debug/dynamic_debug# echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
root@tegra:/sys/kernel/debug/dynamic_debug# echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
root@tegra:/sys/kernel/debug/dynamic_debug# echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
root@tegra:/sys/kernel/debug/dynamic_debug# echo 2 > /sys/kernel/debug/camrtc/log-level
root@tegra:/sys/kernel/debug/dynamic_debug# echo 1 > /sys/kernel/debug/tracing/events/camera_common/enable
root@tegra:/sys/kernel/debug/dynamic_debug# echo > /sys/kernel/debug/tracing/trace
root@tegra:/sys/kernel/debug/dynamic_debug# cat /sys/kernel/debug/tracing/trace
# tracer: nop
# entries-in-buffer/entries-written: 0/0   #P:8
#                                _-----=> irqs-off
#                               / _----=> need-resched
#                              | / _---=> hardirq/softirq
#                              || / _--=> preempt-depth
#                              ||| /     delay
#           TASK-PID     CPU#  ||||   TIMESTAMP  FUNCTION
root@tegra:/sys/kernel/debug/dynamic_debug# v4l2-ctl -d /dev/video0  --set-ctrl sensor_mode=1 --set-fmt-video=width=1920,height=1536 --stream-mmap --stream-to-host 192.168.1.111
                VIDIOC_CROPCAP returned -1 (Inappropriate ioctl for device)
                VIDIOC_G_STD returned -1 (Inappropriate ioctl for device)
                VIDIOC_G_DV_TIMINGS returned -1 (Inappropriate ioctl for device)
^C
root@tegra:/sys/kernel/debug/dynamic_debug# cat /sys/kernel/debug/tracing/trace > /home/robot/trace.log
root@tegra:/sys/kernel/debug/dynamic_debug# dmesg > /home/robot/dmesg.log
root@tegra:/sys/kernel/debug/dynamic_debug# v4l2-ctl -d /dev/video0 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
        Type: Video Capture
        [0]: 'YUYV' (YUYV 4:2:2)
                Size: Discrete 1920x1080
                        Interval: Discrete 0.033s (30.000 fps)
                Size: Discrete 1920x1536
                        Interval: Discrete 0.100s (10.000 fps)
        [1]: 'YUYV' (YUYV 4:2:2)
Block Diagram:
Sensor Info:
root@tegra:/home/robot# cat /etc/nv_tegra_release
# R35 (release), REVISION: 4.1, GCID: 33958178, BOARD: t186ref, EABI: aarch64, DATE: Tue Aug  1 19:57:35 UTC 2023
trace log:
trace.log (47.9 KB)
dmesg:
dmesg.log (80.6 KB)
dts:
tegra234-camera-ar0233-max96712-2lan-port2-10fps.dtsi.txt (28.7 KB)
dts.txt (426.7 KB)
note:
pix_clk_hz = “38500000”; //2200x1750(1920x1536)
serdes_pix_clk_hz = “187500000”;
Frame rate = 10 fps
Do you mean 2 cameras not working simultaneously or the 2th camera can’t work?
From the trace log it could be the vc-id incorrect.
     kworker/1:9-167     [001] ....   312.701609: rtcpu_vinotify_event: tstamp:10578707878 cch:0 vi:1 tag:CHANSEL_SHORT_FRAME channel:0x04 frame:0 vi_tstamp:338515090624 data:0x0550200001000000
OK, thank you!
