HuiW
#1
Hi
Followed the USB tuning guide to tune USB eye diagram.
From p14 of Jetson_TX1_USB_Tuning_Guide_Application_Note.pdf ( see below)
We will need a SW to get TX1 USB drive strength with our adjusted offset value to set the register.
Is there a way to get the tool?
Thank you for any advice,
Trumany
#3
Devmem2 can be used to w/r register, please install it.
HuiW
#4
Hi Trumany,
Thank you for your prompt support.
Yes. We do use devmem2 to tune.
Not sure the doc p13 shows HS_CURR_LEVEL, TERM_RANGE_ADJ can be read by devmem2.
Thank you,
Trumany
#5
The registers that can be w/r are included in tuning guide.
