A USB3.0 Camera GmbH DFM 37UR0234-ML recognize as FX3 micro-controller (DFU mode) on orin nx when cold booting
orin NX上 GmbH DFM 37UR0234-ML usb3.0的相机 断电启动被识别为FX3 micro-controller (DFU mode)
现象:
USB3.0的相机 接在 核心板 原生usb端口, 断电启动, 相机无法识别,
识别成: Bus 001 Device 004: ID 04b4:00f3 Cypress Semiconductor Corp. FX3 micro-controller (DFU mode)
如果重新插拔一下,可以识别成:Bus 002 Device 003: ID 199e:949e The Imaging Source Europe GmbH DFM 37UR0234-ML
在不重新插拔的情况下,是否有其他方案让相机断电启动后可以正常工作?
ps: 在x86 pc上尝试过,断电启动可以正常识别出。
USB3.0相机电气参数:
Interface USB 3.1gen1
Supply Voltage 4.75V DC to 5.25V DC
Current Consumption ~270mA @5V DC
已经从论坛查找如下方法,全部无法工作
1) 端口解码:
sudo sh -c “echo -n ‘1-2’ > /sys/bus/usb/drivers/usb/unbind”
sleep 3
sudo sh -c “echo -n ‘1-2’ > /sys/bus/usb/drivers/usb/bind”
2)端口断电
sudo uhubctl -l 2-1 -a off
No compatible devices detected at location 2-1!
Run with -h to get usage info.
3)/boot/extlinux/extlinux.conf 中增加usbcore的延时也无法识别
usbcore.initial_delay=6000
目前判断是orin nx下 启动过程 usb电源存在波动或者 usb枚举时间过短打断了设备启动过程,导致设备进入DFU模式, 必须断电重新初始化才能进入正常工作状态。
相同问题:系统启动后,是否有办法对原生的USB端口进行断电?
#系统版本:
cat /etc/nv_tegra_release
R36 (release), REVISION: 4.7, GCID: 42132812, BOARD: generic, EABI: aarch64, DATE: Thu Sep 18 22:54:44 UTC 2025
KERNEL_VARIANT: oot
TARGET_USERSPACE_LIB_DIR=nvidia
TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia
#demsg日志:
sudo dmesg |grep usb
[ 0.000000] Kernel command line: root=PARTUUID=414039fd-89a5-4bd3-b4bf-00c703a6cc10 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 video=efifb:off console=tty0 usbcore.initial_delay=6000 bl_prof_dataptr=2031616@0x471E10000 bl_prof_ro_ptr=65536@0x471E00000
[ 0.085491] usbcore: registered new interface driver usbfs
[ 0.085503] usbcore: registered new interface driver hub
[ 0.085512] usbcore: registered new device driver usb
[ 0.184562] usbcore: registered new interface driver usb-storage
[ 1.596462] usbcore: registered new interface driver usbhid
[ 1.596469] usbhid: USB HID core driver
[ 1.662425] usbcore: registered new interface driver snd-usb-audio
[ 1.819235] tegra-xusb 3610000.usb: Adding to iommu group 2
[ 1.833558] tegra-xusb 3610000.usb: Firmware timestamp: 2023-02-10 03:48:10 UTC
[ 1.833565] tegra-xusb 3610000.usb: xHCI Host Controller
[ 1.833574] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 1
[ 1.834296] tegra-xusb 3610000.usb: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000010810
[ 1.834315] tegra-xusb 3610000.usb: irq 124, io mem 0x03610000
[ 1.834423] tegra-xusb 3610000.usb: xHCI Host Controller
[ 1.834427] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 2
[ 1.834430] tegra-xusb 3610000.usb: Host supports USB 3.1 Enhanced SuperSpeed
[ 2.167553] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 2.444108] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 2.715555] usb 1-2.1: new high-speed USB device number 3 using tegra-xusb
[ 3.107554] usb 1-2.2: new high-speed USB device number 4 using tegra-xusb
[ 3.415554] usb 1-2.1.1: new low-speed USB device number 5 using tegra-xusb
[ 3.570670] input: HID 046a:010d as /devices/platform/bus@0/3610000.usb/usb1/1-2/1-2.1/1-2.1.1/1-2.1.1:1.0/0003:046A:010D.0001/input/input1
[ 3.628943] hid-generic 0003:046A:010D.0001: input,hidraw0: USB HID v1.11 Keyboard [HID 046a:010d] on usb-3610000.usb-2.1.1/input0
[ 3.635423] input: HID 046a:010d as /devices/platform/bus@0/3610000.usb/usb1/1-2/1-2.1/1-2.1.1/1-2.1.1:1.1/0003:046A:010D.0002/input/input2
[ 3.692684] hid-generic 0003:046A:010D.0002: input,hidraw1: USB HID v1.11 Device [HID 046a:010d] on usb-3610000.usb-2.1.1/input1
[ 3.795560] usb 1-2.1.4: new low-speed USB device number 6 using tegra-xusb
[ 3.932830] input: Logitech USB Optical Mouse as /devices/platform/bus@0/3610000.usb/usb1/1-2/1-2.1/1-2.1.4/1-2.1.4:1.0/0003:046D:C077.0003/input/input3
[ 3.933406] hid-generic 0003:046D:C077.0003: input,hidraw2: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-3610000.usb-2.1.4/input0
[ 5.448077] tegra-xudc 3550000.usb: Adding to iommu group 4
[ 12.667401] usb0: HOST MAC 3e:1e:d0:8f:68:6c
[ 12.667409] usb0: MAC 3e:1e:d0:8f:68:6d
[ 12.668109] usb1: HOST MAC 3e:1e:d0:8f:68:6e
[ 12.668113] usb1: MAC 3e:1e:d0:8f:68:6f
[ 12.669181] tegra-xudc 3550000.usb: EP 0 (type: ctrl, dir: out) enabled
[ 12.679668] l4tbr0: port 1(usb0) entered blocking state
[ 12.679733] l4tbr0: port 1(usb0) entered disabled state
[ 12.680216] device usb0 entered promiscuous mode
[ 12.686668] l4tbr0: port 2(usb1) entered blocking state
[ 12.686685] l4tbr0: port 2(usb1) entered disabled state
[ 12.686837] device usb1 entered promiscuous mode
[ 1016.610808] usb 1-2.1: USB disconnect, device number 3 —尝试unbind and bind无效
[ 1016.610824] usb 1-2.1.1: USB disconnect, device number 5
[ 1016.809284] usb 1-2.1.4: USB disconnect, device number 6
[ 1016.858448] usb 1-2.2: USB disconnect, device number 4
[ 1025.647785] tegra-xusb 3610000.usb: Firmware timestamp: 2023-02-10 03:48:10 UTC
[ 1026.284983] usb 1-2.1: new high-speed USB device number 7 using tegra-xusb
[ 1026.676768] usb 1-2.2: new high-speed USB device number 8 using tegra-xusb
[ 1026.980766] usb 1-2.1.1: new low-speed USB device number 9 using tegra-xusb
[ 1027.142713] input: HID 046a:010d as /devices/platform/bus@0/3610000.usb/usb1/1-2/1-2.1/1-2.1.1/1-2.1.1:1.0/0003:046A:010D.0004/input/input8
[ 1027.201136] hid-generic 0003:046A:010D.0004: input,hidraw0: USB HID v1.11 Keyboard [HID 046a:010d] on usb-3610000.usb-2.1.1/input0
[ 1027.208803] input: HID 046a:010d as /devices/platform/bus@0/3610000.usb/usb1/1-2/1-2.1/1-2.1.1/1-2.1.1:1.1/0003:046A:010D.0005/input/input9
[ 1027.269022] hid-generic 0003:046A:010D.0005: input,hidraw1: USB HID v1.11 Device [HID 046a:010d] on usb-3610000.usb-2.1.1/input1
[ 1027.372740] usb 1-2.1.4: new low-speed USB device number 10 using tegra-xusb
[ 1027.512220] input: Logitech USB Optical Mouse as /devices/platform/bus@0/3610000.usb/usb1/1-2/1-2.1/1-2.1.4/1-2.1.4:1.0/0003:046D:C077.0006/input/input10
[ 1027.512420] hid-generic 0003:046D:C077.0006: input,hidraw2: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-3610000.usb-2.1.4/input0
[ 2199.666913] usb 1-2.2: USB disconnect, device number 8 ----拔出,重新插拔后,可以正常识别
[ 2209.340943] usb 2-3: new SuperSpeed USB device number 3 using tegra-xusb
[ 2209.362667] usb 2-3: LPM exit latency is zeroed, disabling LPM.
[ 2209.400947] usb 2-3: Found UVC 1.10 device DFM 37UR0234-ML (199e:949e)
[ 2209.405916] usbcore: registered new interface driver uvcvideo
Are you talking about a Orin NX devkit or custom board case?
Or you don’t know what my question mean here?
test on a Orin NX custom board and agx orin devkit。
Which port of Orin AGX devkit got tested here?
On the type A port or the type C port?
Type A 。 the camera side is type c。
Just to clarify. For a custom board, this depends on your hardware design.
If you have a GPIO to control the vbus, then it might happen. If there is not, then won’t have a method to really reset the power.
Is there a guide or reference for this?
Are your the hardware engineer that makes this custom board? or do you have the hardware engineer there?
This question could be answered by the hardware engineer who made that custom board directly.
The problem here is not about a guide or reference. Your board is already there.
yes, we have hardware engineer. he made the custom board.
Please check with him if he/she has a load switch for vbus control.
If the vbus is always-on then not be able to toggle the reset.
