A warning occurred when installing JetPack components using the SDK Manager
When using the SDK Manager to install the JetPack components, a warning appeared. The version of my target device is 35.6.2.
Could you provide the result of below commands:
 cat /etc/nv_tegra_release
Hi DavidDDD,
The execution result of the instruction is as follows:
rk@rk-desktop:~$ cat /etc/nv_tegra_release
R35 (release), REVISION: 6.2, GCID: 40633251, BOARD: t186ref, EABI: aarch64, DATE: Fri May 16 02:08:18 UTC 2025
rk@rk-desktop:~$
Have you run sudo apt upgrade in your device ?
Could you run below commands to get JP components?
sudo apt install nvidia-jetpack
Hi DavidDDD,
thanks for your reply!
Firstly, I didn’t run sudo apt upgrade in my device.
Secondly,Our company installs the JetPack components internally through the SDK Manager, rather than by using commands.
I ignored the warning from the SDK Manager and the installation was successful. The prompt was as follows:
Thus, does the JP components are functioning properly?
Hi DavidDDD
I’m very sorry. Since we haven’t verified the environment of the JetPack component, we are unable to conduct the test.
