There are two Graphics Cards on my PC. One is RTX 3090 and another one is A100. My main purpose is to install the A100 card. When I install A100 card on this PC, I enabled the CSM, and 4G encoding (Above 4G). However I cannot switch to integrated gpu graphics which disappeared when I enabled CSM. So I used a RTX 3090 at hand to output the graphics and it worked. But when I installed ubuntu server and sudo apt install nvidia-driver-###-server/open/None
. I can only find the 3090 card in nvidia-smi. Meantime, all these can be finished in an SSH terminal because the HDMI output is totally black. I tried many combinations like download drivers from the official website or desktop or server.
This is the output of lshw
and I smmarized with ChatGPT.
Based on the information provided in the output of the sudo lshw -short
command, here are the details of the hardware components of the system:
- CPU: 13th Gen Intel(R) Core™ i9-13900K
- Motherboard: ROG MAXIMUS Z790 HERO
- Graphics Card 1: GA100 [A100 PCIe 80GB]
- Graphics Card 2: GA102 [GeForce RTX 3090]
- PCI Device 1: Samsung SSD 980 PRO 2TB
- PCI Device 2: Intel Corporation Network Interface (wlp0s20f3)
- RAM: 128GB System Memory
The command nvidia-smi worked before. But when I write the topic it outputs like this
$ nvidia-smi
Unable to determine the device handle for GPU0000:02:00.0: Unknown Error
My next try is buying an AMD graphic card RX580. I want to use this card to cheat the hardware and system.
What can I do to make A100 available? Thank you for your help in advance.
