Hi!
We just discovered that Audio2face is Not yet multi-gpu.
I wish this would be fixed soon :)
Pekka
Hi!
Pekka
Hello @pekka.varis! I’ve been reporting your Multi-GPU issues with the team and they are working on it! I am reaching out to the leads for more information on why you are running into so many issues. I will get back to you as soon as I can!
@pekka.varis What type of problems are you encountering with multi-GPU and Audio2Face? Does the application just not work?
It works ok, but there is no:
Create and Machinima show all the GPU´s here.
It should be at the bottom of those settings and ON by default.
From these & performance tests, I assume that A2F is just not multi GPU right now…
