A6000 PCIe link speed down Gen1
I have several servers and I connected NVIDIA RTX A6000.
But they all have same issue PCIe link speed down to Gen1.
When I check BIOS and boot dmesg, it looks normal(System speed), but why is it downgraded to Gen1 when I do lspci after booting?
  • lspci
    LnkCap: Port #0, Speed 8GT/s, Width x16, ASPM L0s L1, Exit Latency L0s <512ns, L1 <4us
    ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
    LnkCtl: ASPM Disabled; RCB 64 bytes, Disabled- CommClk+
    ExtSynch- ClockPM+ AutWidDis- BWInt- AutBWInt-
    LnkSta: Speed 2.5GT/s (downgraded), Width x16 (ok)
    TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
  • nvidia smi
    | NVIDIA-SMI 550.54.15 Driver Version: 550.54.15 CUDA Version: 12.4 |
    | GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
    | | | MIG M. |
    | 0 NVIDIA RTX A6000 Off | 00000000:01:00.0 Off | Off |
    | 31% 51C P8 30W / 300W | 1MiB / 49140MiB | 0% Default |
    | | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
  • dmesg
    [ 1.966121] pci 0000:d8:00.0: 126.024 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x8 link at 0000:d7:01.0 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
This is normal due to power saving, the gpu is idle. Once you use it, it will switch to gen 4 speed.
Can I disable it? Always stay 16GT
