in my app I have one OptiX 7.0.0 IAS which contains all subsets instances of GASes.
I wonder how the AABB bounding boxes must be defined for custom primitives in the GAS and IAS,
when a transform matrix is applied in IAS and no other transform nodes are used between IAS and GAS.
OptixInstance* optix_instances = ...
optix_instances[index].transform = transform matrix
The AABB of the GAS (in primitive_input.aabbArray.aabbBuffers) then seems to be a local AABB around that transformed location, right?
In my example I have a sphere at location 11.0, 4.0, -7.0 with radius 8.0
optix_instances[index].transform looks like:
1.000000 0.000000 0.000000 11.000000
0.000000 1.000000 0.000000 4.000000
0.000000 0.000000 1.000000 -7.000000
And the bounding box in the GAS:
AABB min= -8.000000 -8.000000 -8.000000 max= 8.000000 8.000000 8.000000
(I yet ignore rotations/shearing/scaling)
// in the GAS:
OptixBuildInput primitive_input = {};
primitive_input.type = OPTIX_BUILD_INPUT_TYPE_CUSTOM_PRIMITIVES;
primitive_input.aabbArray.aabbBuffers = &d_aabb_buffer;
primitive_input.aabbArray.numPrimitives = primitives;
Additionally in the IAS I then add an AABB, which is required when using custom primitves.
in my example that then also looks like this:
Cause if I transform it, wrong output is present; so obviously the transform in the IAS is applied also there on the AABB; and no additional action is requried, or do I miss something?
So all the AABB’s need to be defined locally when a transform matrix is used in the IAS?
The final location then is ensured by the optix_instances[index].transform in the IAS?
Is that correct?
In my example the primitive is a sphere using a “constant medium”, implemented similar to:
https://devtalk.nvidia.com/default/topic/1057855/optix/-solved-constant-medium-sphere/post/5364617
The center of the sphere (translation part of the transform matrix) simply is directly present in world space in the intersection program.
Maybe this is the reason, why I need local AABBs ?
Thank you!
My system: OptiX 7.0.0 SDK CUDA 10.1.243 GTX 1050 2GB Win10PRO 64bit (version 1809; build 17763.107) device driver: 436.48 VS2019 v16.4.2 (toolkit v140 of VS2015)
