is there a option to disable automatic compression of asset files?
I found command line option -0 should do the job, but I don’t know how to pass it to appt from visual studio project
Unfortunately you cannot do that via the Visual Studio project, but since Nsight Tegra calls Ant to build an APK, any workaround that’s applicable to Ant should be applicable to Nsight Tegra as well.
The following Android issue page seems to describe one of the ways to do that: https://code.google.com/p/android/issues/detail?id=23894
