I have uninstalled everything but Launcher and reinstalled Code.
I have an RTX 4090 with 24 GB.
Mon Mar 20 07:00:33 2023
| NVIDIA-SMI 528.49 Driver Version: 528.49 CUDA Version: 12.0 |
| GPU Name TCC/WDDM | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce … WDDM | 00000000:01:00.0 Off | Off |
| 0% 43C P8 32W / 450W | 1953MiB / 24564MiB | 21% Default |
| | | N/A |
Here are the errors in the console.
2023-03-20 05:54:48 [Error] [gpu.foundation.plugin] CUDA processor count (1) does not match graphics processor count (2)
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/database/DirtyPageCopy.compute.hlsl’.
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/database/DirtyPageCopy.compute.hlsl
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/database/DirtyElementsCopy.compute.hlsl’.
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/database/DirtyElementsCopy.compute.hlsl
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/scenedb/SparseMemCopy.compute.hlsl’.
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/scenedb/SparseMemCopy.compute.hlsl
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/utils/PrefixScanBuffer.compute.hlsl’.
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/utils/PrefixScanBuffer.compute.hlsl
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/utils/PrefixScanTexture.compute.hlsl’.
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/utils/PrefixScanTexture.compute.hlsl
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/lighting/EnvironmentPreprocessingLatLong.compute.hlsl’.
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/lighting/EnvironmentPreprocessingLatLong.compute.hlsl
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/lighting/EnvironmentPreprocessingLatLongConversion.compute.hlsl’.
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/lighting/EnvironmentPreprocessingLatLongConversion.compute.hlsl
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/filters/LowPass.cs.hlsl’.
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/filters/LowPass.cs.hlsl
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/lighting/EnvironmentPreprocessingApproxIBL.cs.hlsl’.
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/lighting/EnvironmentPreprocessingApproxIBL.cs.hlsl
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/scenedb/TranslateInstancePosition.compute.hlsl’.
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/scenedb/TranslateInstancePosition.compute.hlsl
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/scenedb/ValidateSbt.compute.hlsl’.
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/scenedb/ValidateSbt.compute.hlsl
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/scenedb/ProceduralAabb.comp.hlsl’.
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/scenedb/ProceduralAabb.comp.hlsl
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/scenedb/Skinning.comp.hlsl’.
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/scenedb/Skinning.comp.hlsl
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/scenedb/SkinNormal.comp.hlsl’.
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/scenedb/SkinNormal.comp.hlsl
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/scenedb/NormalGeneration.comp.hlsl’.
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/scenedb/NormalGeneration.comp.hlsl
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/scenedb/VertexPulling.comp.hlsl’.
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/scenedb/VertexPulling.comp.hlsl
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/rasterizing/Line.vertex.hlsl’.
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/rasterizing/Line.vertex.hlsl
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/rasterizing/Line.pixel.hlsl’.
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/rasterizing/Line.geometry.hlsl’.
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/rasterizing/Point.geometry.hlsl’.
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/rasterizing/Line.pixel.hlsl
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/rasterizing/Point.geometry.hlsl
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/rasterizing/Line.geometry.hlsl
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/rasterizing/Point.pixel.hlsl’.
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/rasterizing/Point.pixel.hlsl
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/system/GenerateMipMap.comp.hlsl’.
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/system/GenerateMipMap.comp.hlsl
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] Failed to async compile compute shader: rtx/system/GenerateMipMap.comp.hlsl
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] Failed to compile compute shader: rtx/system/GenerateMipMap.comp.hlsl
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/raytracing/SimpleMiss.ms.hlsl’.
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/raytracing/SimpleMiss.ms.hlsl
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/lightspeed/ReLAX/PackInputData.cs.hlsl’.
2023-03-20 05:54:57 [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/lightspeed/ReLAX/PackInputData.cs.hlsl
2023-03-20 05:54:57 [Error] [rtx.denoising.plugin] Failed to async compile compute shader: rtx/lightspeed/ReLAX/PackInputData.cs.hlsl
2023-03-20 05:54:57 [Error] [carb.scenerenderer-rtx.plugin] Failed to create context for rtx::denoising
Any advice greatly appreciated.
Thanks,
Dave
