Abnormal frame_meta->source_id when using [source-list]
**• Hardware Platform (GPU) RTX 3060
**• DeepStream Version 7.0
• TensorRT Version
**• NVIDIA GPU Driver Version (valid for GPU only) CUDA12.1
• Issue Type (questions)
I used the following config file:
[source-list]
num-source-bins=2
list=rtsp://admin:admin123@10.144.1.111:554/profile1;rtsp://admin:admin123@10.144.1.112:554/profile1
sensor-id-list=0;1
sensor-name-list=cam0;cam1
use-nvmultiurisrcbin=0
max-batch-size=2
stream-name-display=1
[source-attr-all]
enable=1
# Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=4
gpu-id=0
cudadec-memtype=0
rtsp-reconnect-interval-sec=10
rtsp-reconnect-attempts=-1
select-rtp-protocol=4
The program can successfully run two RTSP streams, but both frame_meta->source_id values are read as 0. Why is this happening?
What does your pipeline look like? Which element’s pad in the pipeline do you get this value from? If you use a tiler element, the value in the meta data may be modified.
I’m using the DeepStream-app sample.
When I use the [source0] , [source1] , [source2] configuration method, I can correctly get the source_id for each source.
However, when I switch to using [source-list] , all the source_id values are returned as 0.
Which pad did you get it on? Can you share how you modified deepstream-app?
The different configuration setups are all shown in the following code:
static void all_bbox_generated(AppCtx *appCtx, GstBuffer *buf, NvDsBatchMeta *batch_meta, guint index)
    guint num_male = 0;
    guint num_female = 0;
    guint num_objects[128];
    memset(num_objects, 0, sizeof(num_objects));
    frameProcessor.processConfigTime(output_time_interval);
    for (NvDsMetaList *l_frame = batch_meta->frame_meta_list; l_frame != NULL; l_frame = l_frame->next)
        // NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) l_frame->data;
        NvDsFrameMeta *frame_meta = reinterpret_cast<NvDsFrameMeta *>(l_frame->data);
        int64 current_timestamp = TimeUtils::currentTimeInMillis();
        frameProcessor.processFrame(frame_meta, current_timestamp);
        std::cout << "[DEBUG] frame_num = " << frame_meta->frame_num
          << ", source_id = " << frame_meta->source_id
          << ", pad_index = " << frame_meta->pad_index << std::endl;
[DEBUG] frame_num = 0, source_id = 0, pad_index = 0
After my recent testing, I found that when using [source0], [source1], [source2], the frame_meta->source_id values are also all 0. However, this issue does not occur when using the deepstream-app from DeepStream version 6.3.
This should be normal, all_bbox_generated is called after demux/tiler This means that the batch has been split. and the parameter guint index represents source_id.
Can you refer to this faq then get the pipeline dot file ?
Here is my sample configrutation file.
# SPDX-FileCopyrightText: Copyright (c) 2018-2022 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
# SPDX-License-Identifier: LicenseRef-NvidiaProprietary
# NVIDIA CORPORATION, its affiliates and licensors retain all intellectual
# property and proprietary rights in and to this material, related
# documentation and any modifications thereto. Any use, reproduction,
# disclosure or distribution of this material and related documentation
# without an express license agreement from NVIDIA CORPORATION or
# its affiliates is strictly prohibited.
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[source-list]
num-source-bins=2
list=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4;file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h265.mp4
sensor-id-list=0;1
max-batch-size=2
[source-attr-all]
enable=2
type=2
gpu-id=0
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink/nv3dsink (Jetson only) 3=File
type=1
sync=1
source-id=0
gpu-id=0
nvbuf-memory-type=0
[sink1]
enable=1
type=1
sync=1
source-id=1
gpu-id=0
nvbuf-memory-type=0
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
buffer-pool-size=4
batch-size=4
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
width=1920
height=1080
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
## If set to TRUE, system timestamp will be attached as ntp timestamp
## If set to FALSE, ntp timestamp from rtspsrc, if available, will be attached
# attach-sys-ts-as-ntp=1
# config-file property is mandatory for any gie section.
# Other properties are optional and if set will override the properties set in
# the infer config file.
[primary-gie]
enable=1
gpu-id=0
model-engine-file=../../models/Primary_Detector/resnet18_trafficcamnet_pruned.onnx_b4_gpu0_int8.engine
batch-size=4
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary.txt
[tracker]
enable=1
# For NvDCF and NvDeepSORT tracker, tracker-width and tracker-height must be a multiple of 32, respectively
tracker-width=960
tracker-height=544
ll-lib-file=/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
# ll-config-file required to set different tracker types
# ll-config-file=config_tracker_IOU.yml
# ll-config-file=config_tracker_NvSORT.yml
ll-config-file=config_tracker_NvDCF_perf.yml
# ll-config-file=config_tracker_NvDCF_accuracy.yml
# ll-config-file=config_tracker_NvDeepSORT.yml
gpu-id=0
display-tracking-id=1
[secondary-gie0]
enable=1
model-engine-file=../../models/Secondary_VehicleTypes/resnet18_vehicletypenet_pruned.onnx_b16_gpu0_int8.engine
gpu-id=0
batch-size=16
gie-unique-id=4
operate-on-gie-id=1
operate-on-class-ids=0;
config-file=config_infer_secondary_vehicletypes.txt
[secondary-gie1]
enable=1
model-engine-file=../../models/Secondary_VehicleMake/resnet18_vehiclemakenet_pruned.onnx_b16_gpu0_int8.engine
batch-size=16
gpu-id=0
gie-unique-id=5
operate-on-gie-id=1
config-file=config_infer_secondary_vehiclemake.txt
[tests]
file-loop=0
Then you can get source id as the below code snippet.
static void
all_bbox_generated (AppCtx * appCtx, GstBuffer * buf,
    NvDsBatchMeta * batch_meta, guint index)
  guint num_male = 0;
  memset (num_objects, 0, sizeof (num_objects));
+   printf("source_id %d\n", index);
I noticed that in DeepStream version 6.3, the create_pipeline function is called like this:
if (!create_pipeline(appCtx[i], all_bbox_generated, NULL, perf_cb, overlay_graphics))
But in DeepStream 7.0, it’s used like this:
if (!create_pipeline(appCtx[i], NULL, all_bbox_generated, perf_cb, overlay_graphics))
After changing the create_pipeline parameter order in DeepStream 7.0 to match the one in version 6.3, I was able to access frame_meta->source_id inside the all_bbox_generated callback.
Why was this change made? What is the difference between these two ways of passing parameters?
There is no difference between DS-6.3 and DS-7.0. The purpose of each parameter is explained in deepstream_app.h
  for (i = 0; i < num_instances; i++) {
    if (!create_pipeline (appCtx[i], NULL,
            all_bbox_generated, perf_cb, overlay_graphics)) {
      NVGSTDS_ERR_MSG_V ("Failed to create pipeline");
      return_value = -1;
      goto done;
Why is it necessary to use
in order to correctly obtain frame_meta->source_id inside the all_bbox_generated callback?
This call simply changes the timing of all_bbox_generated , It is not correct.
Please refer to my comment in the first reply. all_bbox_generated is called after demux/tiler, bbox_generated_post_analytics_cb is called when the batch has not yet been split by nvstreammux.
Then why is it that when I use
I’m able to correctly get frame_meta->source_id?
Or is this usage actually problematic?
Is it true that all_bbox_generated is only supposed to access metadata after the demuxer/tiler?
I have repeatedly explained above that for the four callback functions of create_pipeline, they are added to different elements of the pipeline to represent different processing stages.
You actually replace bbox_generated_post_analytics_cb with all_bbox_generated.
 * @brief  Create DS Anyalytics Pipeline per the appCtx
 *         configurations
 * @param  appCtx [IN/OUT] The application context
 *         providing the config info and where the
 *         pipeline resources are maintained
 * @param  bbox_generated_post_analytics_cb [IN] This callback
 *         shall be triggered after analytics
 *         (PGIE, Tracker or the last SGIE appearing
 *         in the pipeline)
 *         More info: create_common_elements()
 * @param  all_bbox_generated_cb [IN]
 * @param  perf_cb [IN]
 * @param  overlay_graphics_cb [IN]
Generally speaking, the call timing is as follows, please read the code yourself
pgie--> tracker --> sgie -->
demux/tiler --> osd -->
              all_bbox_generated
Thank you very much for your explanation!
