2. Description of Network Connection Abnormality Problem
2.1 After the abnormal Nano module is burned with the system, it cannot automatically obtain an IP address.
2.4 In the same test environment, the network connection of the good GPU module is normal. The only difference is the GPU module.
Test environment:
Laptop + monitor + network cable + official carrier board
The same nano module works fine on another official carrier board. Are there any batch or version differences between the official carrier boards? Could you please analyze the cause?
