Hi @KevinFFF , I have check the code. I think this part of the code has been processed accordingly. I used jetpack 5.0.2. The relevant code is shown below. I don’t think I need to change anything
struct tegracam_ctrl_handler *handler;
struct tegracam_sensor_data *sensor_data;
if (!s_data)
return -EINVAL;
handler = s_data->tegracam_ctrl_hdl;
if (!handler)
return -EINVAL;
sensor_data = &handler->sensor_data;
I’m closing this topic due to there is no update from you for a period, assuming this issue was resolved.
If still need the support, please open a new topic. Thanks
Could you help to use tegrastats to check system status when you are capturing the video?
