Hi dear reader:
I am trying to use AmgX library to solve Ax=b: using block jacobi preconditioned FGMRES solver.
As indicated in the reference, I am using a config file to build the solver temporarily:
mpirun -n 2 ./amgx_mpi_capi -mode dDDI -m ./matrix.mtx -c ../configs/config_file
And in the config file I did as in the reference book said or somewhat it said:
config_version=2
print_grid_stats=1
store_res_history=1
solver(fgmres)=FGMRES
print_solve_stats=1
fgmres:tolerance=0.01
fgmres:max_iters=40
fgmres:gmres_n_restart=10
fgmres:preconditioner(bjacobi)=BLOCK_JACOBI
bjacobi:relaxation_factor=0.5
obtain_timings=1
max_iters=100
monitor_residual=1
Then I got this
Process 1 selecting device 1
Process 0 selecting device 0
License acquired, proceeding
AMGX version 1.2.0-build108
Built on Dec 22 2014, 10:33:38
Compiled with CUDA Runtime 6.5, using CUDA driver 7.0
Cannot read file as JSON object, trying as AMGX config
Converting config string to current config version
Parsing configuration string: exception_handling=1 ;
Reading matrix dimensions in file: ./matrix.mtx
Reading data…
RHS vector was not found. Using RHS b=[1,…,1]^T
Solution vector was not found. Setting initial solution to x=[0,…,0]^T
Finished reading
And then nothing, I cannot see any result. Can somebody help?
Also, how do I set the block size and other things? I cannot find much information about smoother used as preconditioner, the general parameters, FGMRES parameters and pbjacobi parameters are not fully shown in any materials either, can somebody post them or…maybe I missed them somewhere?
