Does the jetson nano act as a master when connecting to an audio codec?
Thank you.
Thank you.
Hi neuezeal,
Please review the Codec as I2S Master/Slave from https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide%2Fasoc_driver.18.2.html%23wwpID0E0WT0HA
In order to perform the following contents by editing the file directly, which path should the file be modified?
403 Forbidden - No such project 😂
Thank you.
Hello!
The text ‘kcontrols’ is not a typo. That is a Linux kernel term for audio mixer controls.
Regards,
Jon
I see. :)
Where can I find this .dtsi file in the kernel source directory?
After changing the .dtsi file, where should I place it and compile the kernel?
Thank you.
