About automation of configuring L4T on Ubuntu host pc
I thought I could automate the process of downloading and unpacking the l4t and the sample root file system using commands such as wget and running the apply_binaries.sh script.
Is it possible?
Thank you.
Thank you.
what prevents you from doing so?
The entire flow is not drawn.
Thank you.
Can we hear some update and sharing from you after done it successfully?
@Hodu
Has the issue been resolved?
Unless there will be an update from you in few days it is proposed to consider the issue resolved.
If you do something on your own and you don’t know, I’ll ask you in part.
Thank you.
