I checked the developer guide for information related to board naming.
Can you provide guidance on what else should be done in the seller’s position?
Thank you.
Thank you.
Maybe you can tell us what do you need here. I don’t have other guidance to share.
This is not a mandatory rule. You can also buy other vendors’ board and see how they provide their own driver package.
To support a Jetson Nano module with your carrier board, you must assign the module/carrier board combination a lower case alphanumeric name.
I saw the phrase “must assign” and thought it was a must. Isn’t it required?
Thank you.
Some vendors only modify minor changes in their driver package while others make a lots of changes.
For example, minor change could be only the board config name. But other other vendors may even change the dtb or cfg name. We don’t have a really precise limitation of what must be changed or must not be changed.
If you customize anything, rename it to your own one if possible. The point is let your customer know this is a custom component but not from nvidia official release.
