After setting up a user account and installing various packages, can I compare the cloned image with the jetson nano ubuntu original image?
I’d like to be able to see the original image and what changes I made.
Can I check it through text or gui?
Thank you.
I don’t think there is any direct comparison. You could list packages installed on both, and then compare the two lists. The command “dpkg -l
” lists all packages currently installed.
Unfortunately, this won’t tell you about all of the config file changes, it only mentions packages as a whole. You could use the “diff
” or “sha1sum
” command on every file, but you’d be spending a lot of time writing some scripts. This might be worthwhile for the “/etc
” directory, but comparing the entire system would be a lot of effort.
