module a_m
use cudafor
contains
subroutine loop(a,b,c)
complex(4) a(2,2),b(2),c(2)
integer k
complex(4),device::a_d(2,2),b_d(2),c_d(2)
k=2
a_d=a
b_d=b
c_d=c
call cu_loop<<<1,1>>>(a_d,b_d,c_d,k)
c=c_d
b=b_d
a=a_d
end subroutine loop
attributes(global) subroutine cu_loop(a_d,b_d,c_d)
use cublas_device
complex(4), device::a_d(2,2),b_d(2),c_d(2)
integer istat
complex(4), parameter:: cone=cmplx(1.0,0.0)
type(cublasHandle)::h
istat=cublasCreate(h)
istat=cublasCgemv(h,cublas_op_t,2,2,cone,a_d,2,b_d,2,cone,c_d,2)
istat=cublasDestroy(h)
end subroutine cu_loop
end a_m
compile with " pgf90 -c a_m.cuf "
PGF90-F-0155-Compiler failed to translate accelerator region (see -Minfo messages): Unexpected address of constant (a_m.cuf: 1)
PGF90/x86-64 Linux 19.4-0: compilation aborted
I don’t know where the problem is ,when I use CublasSgemv(the corresponding variables are also modified),there is no problem,but cublasCgemv has this problem. Any idea?
