It will be a log with opencv3.4.
After installing the package you gave me, I ran cmake and got an error.
An error occurred in 3.3.
Sorry a lot, please help.
cat /tmp/111/opencv-3.4.0/build/CMakeFiles/CMakeError.log
Compilation failed:
source file: ‘/tmp/111/opencv-3.4.0/cmake/checks/cxx11.cpp’
check option: ‘’
===== BUILD LOG =====
Change Dir: /tmp/111/opencv-3.4.0/build/CMakeFiles/CMakeTmp
Run Build Command(s):/usr/bin/make cmTC_c13a9/fast && /usr/bin/make -f CMakeFiles/cmTC_c13a9.dir/build.make CMakeFiles/cmTC_c13a9.dir/build
make[1]: Entering directory ‘/tmp/111/opencv-3.4.0/build/CMakeFiles/CMakeTmp’
Building CXX object CMakeFiles/cmTC_c13a9.dir/cxx11.cpp.o
/usr/bin/c++ -fPIE -o CMakeFiles/cmTC_c13a9.dir/cxx11.cpp.o -c /tmp/111/opencv-3.4.0/cmake/checks/cxx11.cpp
/tmp/111/opencv-3.4.0/cmake/checks/cxx11.cpp:4:2: error: #error “C++11 is not supported”
/tmp/111/opencv-3.4.0/cmake/checks/cxx11.cpp: In function ‘int main()’:
/tmp/111/opencv-3.4.0/cmake/checks/cxx11.cpp:11:10: error: ‘res’ does not name a type
auto res = test();
/tmp/111/opencv-3.4.0/cmake/checks/cxx11.cpp:12:12: error: ‘res’ was not declared in this scope
return res;
CMakeFiles/cmTC_c13a9.dir/build.make:65: recipe for target ‘CMakeFiles/cmTC_c13a9.dir/cxx11.cpp.o’ failed
make[1]: *** [CMakeFiles/cmTC_c13a9.dir/cxx11.cpp.o] Error 1
make[1]: Leaving directory ‘/tmp/111/opencv-3.4.0/build/CMakeFiles/CMakeTmp’
Makefile:121: recipe for target ‘cmTC_c13a9/fast’ failed
make: *** [cmTC_c13a9/fast] Error 2
===== END =====
Build output check failed:
Regex: ‘command line option .* is valid for .* but not for C++’
Output line: ‘cc1plus: warning: command line option ‘-Wmissing-prototypes’ is valid for C/ObjC but not for C++’
Compilation failed:
source file: ‘/tmp/111/opencv-3.4.0/build/CMakeFiles/CMakeTmp/src.cxx’
check option: ’ -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes’
Run Build Command(s):/usr/bin/make cmTC_457a9/fast && /usr/bin/make -f CMakeFiles/cmTC_457a9.dir/build.make CMakeFiles/cmTC_457a9.dir/build
Building CXX object CMakeFiles/cmTC_457a9.dir/src.cxx.o
/usr/bin/c++ -O3 -DNDEBUG -fPIE -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -o CMakeFiles/cmTC_457a9.dir/src.cxx.o -c /tmp/111/opencv-3.4.0/build/CMakeFiles/CMakeTmp/src.cxx
/tmp/111/opencv-3.4.0/build/CMakeFiles/CMakeTmp/src.cxx:1:0: warning: ignoring #pragma [-Wunknown-pragmas]
#pragma
Linking CXX executable cmTC_457a9
/usr/local/bin/cmake -E cmake_link_script CMakeFiles/cmTC_457a9.dir/link.txt --verbose=1
/usr/bin/c++ -O3 -DNDEBUG -rdynamic CMakeFiles/cmTC_457a9.dir/src.cxx.o -o cmTC_457a9
===== END =====
Output line: ‘cc1plus: warning: command line option ‘-Wstrict-prototypes’ is valid for C/ObjC but not for C++’
Compilation failed:
check option: ’ -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wstrict-prototypes’
Run Build Command(s):/usr/bin/make cmTC_e4f27/fast && /usr/bin/make -f CMakeFiles/cmTC_e4f27.dir/build.make CMakeFiles/cmTC_e4f27.dir/build
Building CXX object CMakeFiles/cmTC_e4f27.dir/src.cxx.o
/usr/bin/c++ -O3 -DNDEBUG -fPIE -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wstrict-prototypes -o CMakeFiles/cmTC_e4f27.dir/src.cxx.o -c /tmp/111/opencv-3.4.0/build/CMakeFiles/CMakeTmp/src.cxx
#pragma
Linking CXX executable cmTC_e4f27
/usr/local/bin/cmake -E cmake_link_script CMakeFiles/cmTC_e4f27.dir/link.txt --verbose=1
/usr/bin/c++ -O3 -DNDEBUG -rdynamic CMakeFiles/cmTC_e4f27.dir/src.cxx.o -o cmTC_e4f27
===== END =====
Regex: ‘command line option .* is valid for .* but not for C’
Output line: ‘cc1: warning: command line option ‘-Wsign-promo’ is valid for C++/ObjC++ but not for C’
Compilation failed:
source file: ‘/tmp/111/opencv-3.4.0/build/CMakeFiles/CMakeTmp/src.c’
check option: ’ -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo’
Run Build Command(s):/usr/bin/make cmTC_ac97c/fast && /usr/bin/make -f CMakeFiles/cmTC_ac97c.dir/build.make CMakeFiles/cmTC_ac97c.dir/build
Building C object CMakeFiles/cmTC_ac97c.dir/src.c.o
/usr/bin/cc -O3 -DNDEBUG -fPIE -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -o CMakeFiles/cmTC_ac97c.dir/src.c.o -c /tmp/111/opencv-3.4.0/build/CMakeFiles/CMakeTmp/src.c
/tmp/111/opencv-3.4.0/build/CMakeFiles/CMakeTmp/src.c:1:0: warning: ignoring #pragma [-Wunknown-pragmas]
#pragma
Linking C executable cmTC_ac97c
/usr/local/bin/cmake -E cmake_link_script CMakeFiles/cmTC_ac97c.dir/link.txt --verbose=1
/usr/bin/cc -O3 -DNDEBUG -rdynamic CMakeFiles/cmTC_ac97c.dir/src.c.o -o cmTC_ac97c
===== END =====
Output line: ‘cc1: warning: command line option ‘-Wno-delete-non-virtual-dtor’ is valid for C++/ObjC++ but not for C’
Compilation failed:
check option: ’ -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-narrowing -Wno-delete-non-virtual-dtor’
Run Build Command(s):/usr/bin/make cmTC_b2814/fast && /usr/bin/make -f CMakeFiles/cmTC_b2814.dir/build.make CMakeFiles/cmTC_b2814.dir/build
Building C object CMakeFiles/cmTC_b2814.dir/src.c.o
/usr/bin/cc -O3 -DNDEBUG -fPIE -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-narrowing -Wno-delete-non-virtual-dtor -o CMakeFiles/cmTC_b2814.dir/src.c.o -c /tmp/111/opencv-3.4.0/build/CMakeFiles/CMakeTmp/src.c
#pragma
Linking C executable cmTC_b2814
/usr/local/bin/cmake -E cmake_link_script CMakeFiles/cmTC_b2814.dir/link.txt --verbose=1
/usr/bin/cc -O3 -DNDEBUG -rdynamic CMakeFiles/cmTC_b2814.dir/src.c.o -o cmTC_b2814
===== END =====
Regex: ‘unrecognized .*option’
Output line: ‘cc1plus: warning: unrecognized command line option ‘-Wno-unnamed-type-template-args’’
Compilation failed:
check option: ’ -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wno-narrowing -Wno-delete-non-virtual-dtor -Wno-unnamed-type-template-args’
Run Build Command(s):/usr/bin/make cmTC_ad5d4/fast && /usr/bin/make -f CMakeFiles/cmTC_ad5d4.dir/build.make CMakeFiles/cmTC_ad5d4.dir/build
Building CXX object CMakeFiles/cmTC_ad5d4.dir/src.cxx.o
/usr/bin/c++ -O3 -DNDEBUG -fPIE -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wno-narrowing -Wno-delete-non-virtual-dtor -Wno-unnamed-type-template-args -o CMakeFiles/cmTC_ad5d4.dir/src.cxx.o -c /tmp/111/opencv-3.4.0/build/CMakeFiles/CMakeTmp/src.cxx
#pragma
Linking CXX executable cmTC_ad5d4
/usr/local/bin/cmake -E cmake_link_script CMakeFiles/cmTC_ad5d4.dir/link.txt --verbose=1
/usr/bin/c++ -O3 -DNDEBUG -rdynamic CMakeFiles/cmTC_ad5d4.dir/src.cxx.o -o cmTC_ad5d4
===== END =====
Output line: ‘cc1: warning: unrecognized command line option ‘-Wno-unnamed-type-template-args’’
Compilation failed:
check option: ’ -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-narrowing -Wno-unnamed-type-template-args’
Run Build Command(s):/usr/bin/make cmTC_793b3/fast && /usr/bin/make -f CMakeFiles/cmTC_793b3.dir/build.make CMakeFiles/cmTC_793b3.dir/build
Building C object CMakeFiles/cmTC_793b3.dir/src.c.o
/usr/bin/cc -O3 -DNDEBUG -fPIE -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-narrowing -Wno-unnamed-type-template-args -o CMakeFiles/cmTC_793b3.dir/src.c.o -c /tmp/111/opencv-3.4.0/build/CMakeFiles/CMakeTmp/src.c
#pragma
Linking C executable cmTC_793b3
/usr/local/bin/cmake -E cmake_link_script CMakeFiles/cmTC_793b3.dir/link.txt --verbose=1
/usr/bin/cc -O3 -DNDEBUG -rdynamic CMakeFiles/cmTC_793b3.dir/src.c.o -o cmTC_793b3
===== END =====
Output line: ‘cc1plus: warning: unrecognized command line option ‘-Wno-implicit-fallthrough’’
Compilation failed:
check option: ’ -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wno-narrowing -Wno-delete-non-virtual-dtor -Wno-comment -Wno-implicit-fallthrough’
Run Build Command(s):/usr/bin/make cmTC_2694c/fast && /usr/bin/make -f CMakeFiles/cmTC_2694c.dir/build.make CMakeFiles/cmTC_2694c.dir/build
Building CXX object CMakeFiles/cmTC_2694c.dir/src.cxx.o
/usr/bin/c++ -O3 -DNDEBUG -fPIE -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wno-narrowing -Wno-delete-non-virtual-dtor -Wno-comment -Wno-implicit-fallthrough -o CMakeFiles/cmTC_2694c.dir/src.cxx.o -c /tmp/111/opencv-3.4.0/build/CMakeFiles/CMakeTmp/src.cxx
#pragma
Linking CXX executable cmTC_2694c
/usr/local/bin/cmake -E cmake_link_script CMakeFiles/cmTC_2694c.dir/link.txt --verbose=1
/usr/bin/c++ -O3 -DNDEBUG -rdynamic CMakeFiles/cmTC_2694c.dir/src.cxx.o -o cmTC_2694c
===== END =====
Output line: ‘cc1: warning: unrecognized command line option ‘-Wno-implicit-fallthrough’’
Compilation failed:
check option: ’ -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-narrowing -Wno-comment -Wno-implicit-fallthrough’
Run Build Command(s):/usr/bin/make cmTC_87a0e/fast && /usr/bin/make -f CMakeFiles/cmTC_87a0e.dir/build.make CMakeFiles/cmTC_87a0e.dir/build
Building C object CMakeFiles/cmTC_87a0e.dir/src.c.o
/usr/bin/cc -O3 -DNDEBUG -fPIE -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-narrowing -Wno-comment -Wno-implicit-fallthrough -o CMakeFiles/cmTC_87a0e.dir/src.c.o -c /tmp/111/opencv-3.4.0/build/CMakeFiles/CMakeTmp/src.c
#pragma
Linking C executable cmTC_87a0e
/usr/local/bin/cmake -E cmake_link_script CMakeFiles/cmTC_87a0e.dir/link.txt --verbose=1
/usr/bin/cc -O3 -DNDEBUG -rdynamic CMakeFiles/cmTC_87a0e.dir/src.c.o -o cmTC_87a0e
===== END =====
Output line: ‘cc1: warning: command line option ‘-fvisibility-inlines-hidden’ is valid for C++/ObjC++ but not for C’
Compilation failed:
check option: ’ -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-narrowing -Wno-comment -fdiagnostics-show-option -Wno-long-long -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -msse -msse2 -msse3 -fvisibility=hidden -fvisibility-inlines-hidden’
Run Build Command(s):/usr/bin/make cmTC_89a85/fast && /usr/bin/make -f CMakeFiles/cmTC_89a85.dir/build.make CMakeFiles/cmTC_89a85.dir/build
Building C object CMakeFiles/cmTC_89a85.dir/src.c.o
/usr/bin/cc -O3 -DNDEBUG -fPIE -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-narrowing -Wno-comment -fdiagnostics-show-option -Wno-long-long -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -msse -msse2 -msse3 -fvisibility=hidden -fvisibility-inlines-hidden -o CMakeFiles/cmTC_89a85.dir/src.c.o -c /tmp/111/opencv-3.4.0/build/CMakeFiles/CMakeTmp/src.c
#pragma
Linking C executable cmTC_89a85
/usr/local/bin/cmake -E cmake_link_script CMakeFiles/cmTC_89a85.dir/link.txt --verbose=1
/usr/bin/cc -O3 -DNDEBUG -rdynamic CMakeFiles/cmTC_89a85.dir/src.c.o -o cmTC_89a85
===== END =====
Determining if the include file linux/videodev.h exists failed with the following output:
Run Build Command(s):/usr/bin/make cmTC_31acd/fast && /usr/bin/make -f CMakeFiles/cmTC_31acd.dir/build.make CMakeFiles/cmTC_31acd.dir/build
Building C object CMakeFiles/cmTC_31acd.dir/CheckIncludeFile.c.o
/usr/bin/cc -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-narrowing -Wno-comment -fdiagnostics-show-option -Wno-long-long -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -msse -msse2 -msse3 -fvisibility=hidden -O3 -DNDEBUG -fPIE -o CMakeFiles/cmTC_31acd.dir/CheckIncludeFile.c.o -c /tmp/111/opencv-3.4.0/build/CMakeFiles/CMakeTmp/CheckIncludeFile.c
/tmp/111/opencv-3.4.0/build/CMakeFiles/CMakeTmp/CheckIncludeFile.c:1:28: fatal error: linux/videodev.h: No such file or directory
compilation terminated.
CMakeFiles/cmTC_31acd.dir/build.make:65: recipe for target ‘CMakeFiles/cmTC_31acd.dir/CheckIncludeFile.c.o’ failed
make[1]: *** [CMakeFiles/cmTC_31acd.dir/CheckIncludeFile.c.o] Error 1
Makefile:121: recipe for target ‘cmTC_31acd/fast’ failed
make: *** [cmTC_31acd/fast] Error 2
Determining if the include file sys/videoio.h exists failed with the following output:
Run Build Command(s):/usr/bin/make cmTC_7c251/fast && /usr/bin/make -f CMakeFiles/cmTC_7c251.dir/build.make CMakeFiles/cmTC_7c251.dir/build
Building C object CMakeFiles/cmTC_7c251.dir/CheckIncludeFile.c.o
/usr/bin/cc -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-narrowing -Wno-comment -fdiagnostics-show-option -Wno-long-long -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -msse -msse2 -msse3 -fvisibility=hidden -O3 -DNDEBUG -fPIE -o CMakeFiles/cmTC_7c251.dir/CheckIncludeFile.c.o -c /tmp/111/opencv-3.4.0/build/CMakeFiles/CMakeTmp/CheckIncludeFile.c
/tmp/111/opencv-3.4.0/build/CMakeFiles/CMakeTmp/CheckIncludeFile.c:1:25: fatal error: sys/videoio.h: No such file or directory
CMakeFiles/cmTC_7c251.dir/build.make:65: recipe for target ‘CMakeFiles/cmTC_7c251.dir/CheckIncludeFile.c.o’ failed
make[1]: *** [CMakeFiles/cmTC_7c251.dir/CheckIncludeFile.c.o] Error 1
Makefile:121: recipe for target ‘cmTC_7c251/fast’ failed
make: *** [cmTC_7c251/fast] Error 2
Determining if the function sgemm_ exists failed with the following output:
Run Build Command(s):/usr/bin/make cmTC_ba42b/fast && /usr/bin/make -f CMakeFiles/cmTC_ba42b.dir/build.make CMakeFiles/cmTC_ba42b.dir/build
Building C object CMakeFiles/cmTC_ba42b.dir/CheckFunctionExists.c.o
/usr/bin/cc -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-narrowing -Wno-comment -fdiagnostics-show-option -Wno-long-long -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -msse -msse2 -msse3 -fvisibility=hidden -DCHECK_FUNCTION_EXISTS=sgemm_ -O3 -DNDEBUG -fPIE -o CMakeFiles/cmTC_ba42b.dir/CheckFunctionExists.c.o -c /usr/local/share/cmake-3.15/Modules/CheckFunctionExists.c
Linking C executable cmTC_ba42b
/usr/local/bin/cmake -E cmake_link_script CMakeFiles/cmTC_ba42b.dir/link.txt --verbose=1
/usr/bin/cc -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-narrowing -Wno-comment -fdiagnostics-show-option -Wno-long-long -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -msse -msse2 -msse3 -fvisibility=hidden -DCHECK_FUNCTION_EXISTS=sgemm_ -O3 -DNDEBUG -Wl,–gc-sections -rdynamic CMakeFiles/cmTC_ba42b.dir/CheckFunctionExists.c.o -o cmTC_ba42b
CMakeFiles/cmTC_ba42b.dir/CheckFunctionExists.c.o: In function main': CheckFunctionExists.c:(.text.startup.main+0xc): undefined reference to
sgemm_’
collect2: error: ld returned 1 exit status
CMakeFiles/cmTC_ba42b.dir/build.make:86: recipe for target ‘cmTC_ba42b’ failed
make[1]: *** [cmTC_ba42b] Error 1
Makefile:121: recipe for target ‘cmTC_ba42b/fast’ failed
make: *** [cmTC_ba42b/fast] Error 2
Output line: ‘cc1plus: warning: command line option ‘-Wno-missing-prototypes’ is valid for C/ObjC but not for C++’
Compilation failed:
check option: ’ -Wno-missing-prototypes’
Run Build Command(s):/usr/bin/make cmTC_7844c/fast && /usr/bin/make -f CMakeFiles/cmTC_7844c.dir/build.make CMakeFiles/cmTC_7844c.dir/build
Building CXX object CMakeFiles/cmTC_7844c.dir/src.cxx.o
/usr/bin/c++ -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wno-narrowing -Wno-delete-non-virtual-dtor -Wno-comment -fdiagnostics-show-option -Wno-long-long -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -msse -msse2 -msse3 -fvisibility=hidden -fvisibility-inlines-hidden -Wno-deprecated -O3 -DNDEBUG -fPIE -Wno-missing-prototypes -o CMakeFiles/cmTC_7844c.dir/src.cxx.o -c /tmp/111/opencv-3.4.0/build/CMakeFiles/CMakeTmp/src.cxx
#pragma
Linking CXX executable cmTC_7844c
/usr/local/bin/cmake -E cmake_link_script CMakeFiles/cmTC_7844c.dir/link.txt --verbose=1
/usr/bin/c++ -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wno-narrowing -Wno-delete-non-virtual-dtor -Wno-comment -fdiagnostics-show-option -Wno-long-long -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -msse -msse2 -msse3 -fvisibility=hidden -fvisibility-inlines-hidden -Wno-deprecated -O3 -DNDEBUG -Wl,–gc-sections -rdynamic CMakeFiles/cmTC_7844c.dir/src.cxx.o -o cmTC_7844c
===== END =====
Output line: ‘cc1plus: warning: unrecognized command line option ‘-Wno-tautological-undefined-compare’’
Compilation failed:
check option: ’ -Wno-tautological-undefined-compare’
Run Build Command(s):/usr/bin/make cmTC_2dacf/fast && /usr/bin/make -f CMakeFiles/cmTC_2dacf.dir/build.make CMakeFiles/cmTC_2dacf.dir/build
Building CXX object CMakeFiles/cmTC_2dacf.dir/src.cxx.o
/usr/bin/c++ -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Winit-self -Wpointer-arith -Wuninitialized -Winit-self -Wno-narrowing -Wno-delete-non-virtual-dtor -Wno-comment -fdiagnostics-show-option -Wno-long-long -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -msse -msse2 -msse3 -fvisibility=hidden -fvisibility-inlines-hidden -Wno-deprecated -Wno-missing-declarations -Wno-shadow -Wno-unused-parameter -Wno-unused-local-typedefs -Wno-sign-compare -Wno-sign-promo -Wno-undef -O3 -DNDEBUG -fPIE -Wno-tautological-undefined-compare -o CMakeFiles/cmTC_2dacf.dir/src.cxx.o -c /tmp/111/opencv-3.4.0/build/CMakeFiles/CMakeTmp/src.cxx
#pragma
Linking CXX executable cmTC_2dacf
/usr/local/bin/cmake -E cmake_link_script CMakeFiles/cmTC_2dacf.dir/link.txt --verbose=1
/usr/bin/c++ -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Winit-self -Wpointer-arith -Wuninitialized -Winit-self -Wno-narrowing -Wno-delete-non-virtual-dtor -Wno-comment -fdiagnostics-show-option -Wno-long-long -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -msse -msse2 -msse3 -fvisibility=hidden -fvisibility-inlines-hidden -Wno-deprecated -Wno-missing-declarations -Wno-shadow -Wno-unused-parameter -Wno-unused-local-typedefs -Wno-sign-compare -Wno-sign-promo -Wno-undef -O3 -DNDEBUG -Wl,–gc-sections -rdynamic CMakeFiles/cmTC_2dacf.dir/src.cxx.o -o cmTC_2dacf
===== END =====
Output line: ‘cc1plus: warning: unrecognized command line option ‘-Wno-unused-const-variable’’
Compilation failed:
check option: ’ -Wno-unused-const-variable’
Run Build Command(s):/usr/bin/make cmTC_c38d4/fast && /usr/bin/make -f CMakeFiles/cmTC_c38d4.dir/build.make CMakeFiles/cmTC_c38d4.dir/build
Building CXX object CMakeFiles/cmTC_c38d4.dir/src.cxx.o
/usr/bin/c++ -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Winit-self -Wpointer-arith -Wuninitialized -Winit-self -Wno-narrowing -Wno-delete-non-virtual-dtor -Wno-comment -fdiagnostics-show-option -Wno-long-long -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -msse -msse2 -msse3 -fvisibility=hidden -fvisibility-inlines-hidden -Wno-deprecated -Wno-missing-declarations -Wno-shadow -Wno-unused-parameter -Wno-unused-local-typedefs -Wno-sign-compare -Wno-sign-promo -Wno-undef -Wno-ignored-qualifiers -Wno-extra -Wno-unused-function -O3 -DNDEBUG -fPIE -Wno-unused-const-variable -o CMakeFiles/cmTC_c38d4.dir/src.cxx.o -c /tmp/111/opencv-3.4.0/build/CMakeFiles/CMakeTmp/src.cxx
#pragma
Linking CXX executable cmTC_c38d4
/usr/local/bin/cmake -E cmake_link_script CMakeFiles/cmTC_c38d4.dir/link.txt --verbose=1
/usr/bin/c++ -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Winit-self -Wpointer-arith -Wuninitialized -Winit-self -Wno-narrowing -Wno-delete-non-virtual-dtor -Wno-comment -fdiagnostics-show-option -Wno-long-long -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -msse -msse2 -msse3 -fvisibility=hidden -fvisibility-inlines-hidden -Wno-deprecated -Wno-missing-declarations -Wno-shadow -Wno-unused-parameter -Wno-unused-local-typedefs -Wno-sign-compare -Wno-sign-promo -Wno-undef -Wno-ignored-qualifiers -Wno-extra -Wno-unused-function -O3 -DNDEBUG -Wl,–gc-sections -rdynamic CMakeFiles/cmTC_c38d4.dir/src.cxx.o -o cmTC_c38d4
===== END =====
Output line: ‘cc1plus: warning: unrecognized command line option ‘-Wno-shorten-64-to-32’’
Compilation failed:
check option: ’ -Wno-shorten-64-to-32’
Run Build Command(s):/usr/bin/make cmTC_a6e7d/fast && /usr/bin/make -f CMakeFiles/cmTC_a6e7d.dir/build.make CMakeFiles/cmTC_a6e7d.dir/build
Building CXX object CMakeFiles/cmTC_a6e7d.dir/src.cxx.o
/usr/bin/c++ -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Winit-self -Wpointer-arith -Wuninitialized -Winit-self -Wno-narrowing -Wno-delete-non-virtual-dtor -Wno-comment -fdiagnostics-show-option -Wno-long-long -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -msse -msse2 -msse3 -fvisibility=hidden -fvisibility-inlines-hidden -Wno-deprecated -Wno-missing-declarations -Wno-shadow -Wno-unused-parameter -Wno-unused-local-typedefs -Wno-sign-compare -Wno-sign-promo -Wno-undef -Wno-ignored-qualifiers -Wno-extra -Wno-unused-function -O3 -DNDEBUG -fPIE -Wno-shorten-64-to-32 -o CMakeFiles/cmTC_a6e7d.dir/src.cxx.o -c /tmp/111/opencv-3.4.0/build/CMakeFiles/CMakeTmp/src.cxx
#pragma
Linking CXX executable cmTC_a6e7d
/usr/local/bin/cmake -E cmake_link_script CMakeFiles/cmTC_a6e7d.dir/link.txt --verbose=1
/usr/bin/c++ -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Winit-self -Wpointer-arith -Wuninitialized -Winit-self -Wno-narrowing -Wno-delete-non-virtual-dtor -Wno-comment -fdiagnostics-show-option -Wno-long-long -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -msse -msse2 -msse3 -fvisibility=hidden -fvisibility-inlines-hidden -Wno-deprecated -Wno-missing-declarations -Wno-shadow -Wno-unused-parameter -Wno-unused-local-typedefs -Wno-sign-compare -Wno-sign-promo -Wno-undef -Wno-ignored-qualifiers -Wno-extra -Wno-unused-function -O3 -DNDEBUG -Wl,–gc-sections -rdynamic CMakeFiles/cmTC_a6e7d.dir/src.cxx.o -o cmTC_a6e7d
===== END =====
Output line: ‘cc1plus: warning: unrecognized command line option ‘-Wno-unused-private-field’’
Compilation failed:
check option: ’ -Wno-unused-private-field’
Run Build Command(s):/usr/bin/make cmTC_223e4/fast && /usr/bin/make -f CMakeFiles/cmTC_223e4.dir/build.make CMakeFiles/cmTC_223e4.dir/build
Building CXX object CMakeFiles/cmTC_223e4.dir/src.cxx.o
/usr/bin/c++ -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wno-narrowing -Wno-delete-non-virtual-dtor -Wno-comment -fdiagnostics-show-option -Wno-long-long -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -msse -msse2 -msse3 -fvisibility=hidden -fvisibility-inlines-hidden -Wno-unused-function -Wno-overloaded-virtual -O3 -DNDEBUG -fPIE -Wno-unused-private-field -o CMakeFiles/cmTC_223e4.dir/src.cxx.o -c /tmp/111/opencv-3.4.0/build/CMakeFiles/CMakeTmp/src.cxx
#pragma
Linking CXX executable cmTC_223e4
/usr/local/bin/cmake -E cmake_link_script CMakeFiles/cmTC_223e4.dir/link.txt --verbose=1
/usr/bin/c++ -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wno-narrowing -Wno-delete-non-virtual-dtor -Wno-comment -fdiagnostics-show-option -Wno-long-long -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -msse -msse2 -msse3 -fvisibility=hidden -fvisibility-inlines-hidden -Wno-unused-function -Wno-overloaded-virtual -O3 -DNDEBUG -Wl,–gc-sections -rdynamic CMakeFiles/cmTC_223e4.dir/src.cxx.o -o cmTC_223e4
===== END =====
