it should have some output which will check all the dependency when configure the cmake at beginning, can you paste the log for that?
It is the result when cmake is run.
cmake -D CMAKE_BUILD_TYPE=RELEASE \
-DCMAKE_INSTALL_PREFIX=/usr/local \ -DWITH_CUDA=ON \ -DINSTALL_PYTHON_EXAMPLES=ON \ -DOPENCV_EXTRA_MODULES_PATH=~/opencv_contrib/modules \ -DBUILD_EXAMPLES=ON \ -DBUILD_opencv_cudacodec=OFF \ -DCMAKE_CXX_FLAGS="" ..
– The CXX compiler identification is GNU 5.4.0
– The C compiler identification is GNU 5.4.0
– Check for working CXX compiler: /usr/bin/c++
– Check for working CXX compiler: /usr/bin/c++ – works
– Detecting CXX compiler ABI info
– Detecting CXX compiler ABI info - done
– Detecting CXX compile features
– Detecting CXX compile features - done
– Check for working C compiler: /usr/bin/cc
– Check for working C compiler: /usr/bin/cc – works
– Detecting C compiler ABI info
– Detecting C compiler ABI info - done
– Detecting C compile features
– Detecting C compile features - done
– Performing Test HAVE_CXX11 (check file: cmake/checks/cxx11.cpp)
– Performing Test HAVE_CXX11 - Failed
– Found PythonInterp: /usr/bin/python2.7 (found suitable version “2.7.12”, minimum required is “2.7”)
– Found PythonLibs: /usr/lib/x86_64-linux-gnu/libpython2.7.so (found suitable exact version “2.7.12”)
– Found PythonInterp: /usr/bin/python3 (found suitable version “3.5.2”, minimum required is “3.4”)
– Could NOT find PythonLibs (missing: PYTHON_LIBRARIES PYTHON_INCLUDE_DIRS) (Required is exact version “3.5.2”)
File “”, line 1, in
ImportError: No module named ‘numpy’
– Looking for ccache - not found
– Performing Test HAVE_CXX_FSIGNED_CHAR
– Performing Test HAVE_CXX_FSIGNED_CHAR - Success
– Performing Test HAVE_C_FSIGNED_CHAR
– Performing Test HAVE_C_FSIGNED_CHAR - Success
– Performing Test HAVE_CXX_W
– Performing Test HAVE_CXX_W - Success
– Performing Test HAVE_C_W
– Performing Test HAVE_C_W - Success
– Performing Test HAVE_CXX_WALL
– Performing Test HAVE_CXX_WALL - Success
– Performing Test HAVE_C_WALL
– Performing Test HAVE_C_WALL - Success
– Performing Test HAVE_CXX_WERROR_RETURN_TYPE
– Performing Test HAVE_CXX_WERROR_RETURN_TYPE - Success
– Performing Test HAVE_C_WERROR_RETURN_TYPE
– Performing Test HAVE_C_WERROR_RETURN_TYPE - Success
– Performing Test HAVE_CXX_WERROR_NON_VIRTUAL_DTOR
– Performing Test HAVE_CXX_WERROR_NON_VIRTUAL_DTOR - Success
– Performing Test HAVE_C_WERROR_NON_VIRTUAL_DTOR
– Performing Test HAVE_C_WERROR_NON_VIRTUAL_DTOR - Success
– Performing Test HAVE_CXX_WERROR_ADDRESS
– Performing Test HAVE_CXX_WERROR_ADDRESS - Success
– Performing Test HAVE_C_WERROR_ADDRESS
– Performing Test HAVE_C_WERROR_ADDRESS - Success
– Performing Test HAVE_CXX_WERROR_SEQUENCE_POINT
– Performing Test HAVE_CXX_WERROR_SEQUENCE_POINT - Success
– Performing Test HAVE_C_WERROR_SEQUENCE_POINT
– Performing Test HAVE_C_WERROR_SEQUENCE_POINT - Success
– Performing Test HAVE_CXX_WFORMAT
– Performing Test HAVE_CXX_WFORMAT - Success
– Performing Test HAVE_C_WFORMAT
– Performing Test HAVE_C_WFORMAT - Success
– Performing Test HAVE_CXX_WERROR_FORMAT_SECURITY
– Performing Test HAVE_CXX_WERROR_FORMAT_SECURITY - Success
– Performing Test HAVE_C_WERROR_FORMAT_SECURITY
– Performing Test HAVE_C_WERROR_FORMAT_SECURITY - Success
– Performing Test HAVE_CXX_WMISSING_DECLARATIONS
– Performing Test HAVE_CXX_WMISSING_DECLARATIONS - Success
– Performing Test HAVE_C_WMISSING_DECLARATIONS
– Performing Test HAVE_C_WMISSING_DECLARATIONS - Success
– Performing Test HAVE_CXX_WMISSING_PROTOTYPES
– Performing Test HAVE_CXX_WMISSING_PROTOTYPES - Failed
– Performing Test HAVE_C_WMISSING_PROTOTYPES
– Performing Test HAVE_C_WMISSING_PROTOTYPES - Success
– Performing Test HAVE_CXX_WSTRICT_PROTOTYPES
– Performing Test HAVE_CXX_WSTRICT_PROTOTYPES - Failed
– Performing Test HAVE_C_WSTRICT_PROTOTYPES
– Performing Test HAVE_C_WSTRICT_PROTOTYPES - Success
– Performing Test HAVE_CXX_WUNDEF
– Performing Test HAVE_CXX_WUNDEF - Success
– Performing Test HAVE_C_WUNDEF
– Performing Test HAVE_C_WUNDEF - Success
– Performing Test HAVE_CXX_WINIT_SELF
– Performing Test HAVE_CXX_WINIT_SELF - Success
– Performing Test HAVE_C_WINIT_SELF
– Performing Test HAVE_C_WINIT_SELF - Success
– Performing Test HAVE_CXX_WPOINTER_ARITH
– Performing Test HAVE_CXX_WPOINTER_ARITH - Success
– Performing Test HAVE_C_WPOINTER_ARITH
– Performing Test HAVE_C_WPOINTER_ARITH - Success
– Performing Test HAVE_CXX_WSHADOW
– Performing Test HAVE_CXX_WSHADOW - Success
– Performing Test HAVE_C_WSHADOW
– Performing Test HAVE_C_WSHADOW - Success
– Performing Test HAVE_CXX_WSIGN_PROMO
– Performing Test HAVE_CXX_WSIGN_PROMO - Success
– Performing Test HAVE_C_WSIGN_PROMO
– Performing Test HAVE_C_WSIGN_PROMO - Failed
– Performing Test HAVE_CXX_WUNINITIALIZED
– Performing Test HAVE_CXX_WUNINITIALIZED - Success
– Performing Test HAVE_C_WUNINITIALIZED
– Performing Test HAVE_C_WUNINITIALIZED - Success
– Performing Test HAVE_CXX_WNO_NARROWING
– Performing Test HAVE_CXX_WNO_NARROWING - Success
– Performing Test HAVE_C_WNO_NARROWING
– Performing Test HAVE_C_WNO_NARROWING - Success
– Performing Test HAVE_CXX_WNO_DELETE_NON_VIRTUAL_DTOR
– Performing Test HAVE_CXX_WNO_DELETE_NON_VIRTUAL_DTOR - Success
– Performing Test HAVE_C_WNO_DELETE_NON_VIRTUAL_DTOR
– Performing Test HAVE_C_WNO_DELETE_NON_VIRTUAL_DTOR - Failed
– Performing Test HAVE_CXX_WNO_UNNAMED_TYPE_TEMPLATE_ARGS
– Performing Test HAVE_CXX_WNO_UNNAMED_TYPE_TEMPLATE_ARGS - Failed
– Performing Test HAVE_C_WNO_UNNAMED_TYPE_TEMPLATE_ARGS
– Performing Test HAVE_C_WNO_UNNAMED_TYPE_TEMPLATE_ARGS - Failed
– Performing Test HAVE_CXX_WNO_COMMENT
– Performing Test HAVE_CXX_WNO_COMMENT - Success
– Performing Test HAVE_C_WNO_COMMENT
– Performing Test HAVE_C_WNO_COMMENT - Success
– Performing Test HAVE_CXX_WNO_IMPLICIT_FALLTHROUGH
– Performing Test HAVE_CXX_WNO_IMPLICIT_FALLTHROUGH - Failed
– Performing Test HAVE_C_WNO_IMPLICIT_FALLTHROUGH
– Performing Test HAVE_C_WNO_IMPLICIT_FALLTHROUGH - Failed
– Performing Test HAVE_CXX_FDIAGNOSTICS_SHOW_OPTION
– Performing Test HAVE_CXX_FDIAGNOSTICS_SHOW_OPTION - Success
– Performing Test HAVE_C_FDIAGNOSTICS_SHOW_OPTION
– Performing Test HAVE_C_FDIAGNOSTICS_SHOW_OPTION - Success
– Performing Test HAVE_CXX_WNO_LONG_LONG
– Performing Test HAVE_CXX_WNO_LONG_LONG - Success
– Performing Test HAVE_C_WNO_LONG_LONG
– Performing Test HAVE_C_WNO_LONG_LONG - Success
– Performing Test HAVE_CXX_PTHREAD
– Performing Test HAVE_CXX_PTHREAD - Success
– Performing Test HAVE_C_PTHREAD
– Performing Test HAVE_C_PTHREAD - Success
– Performing Test HAVE_CXX_FOMIT_FRAME_POINTER
– Performing Test HAVE_CXX_FOMIT_FRAME_POINTER - Success
– Performing Test HAVE_C_FOMIT_FRAME_POINTER
– Performing Test HAVE_C_FOMIT_FRAME_POINTER - Success
– Performing Test HAVE_CXX_FFUNCTION_SECTIONS
– Performing Test HAVE_CXX_FFUNCTION_SECTIONS - Success
– Performing Test HAVE_C_FFUNCTION_SECTIONS
– Performing Test HAVE_C_FFUNCTION_SECTIONS - Success
– Performing Test HAVE_CXX_FDATA_SECTIONS
– Performing Test HAVE_CXX_FDATA_SECTIONS - Success
– Performing Test HAVE_C_FDATA_SECTIONS
– Performing Test HAVE_C_FDATA_SECTIONS - Success
– Performing Test HAVE_CXX_MSSE (check file: cmake/checks/cpu_sse.cpp)
– Performing Test HAVE_CXX_MSSE - Success
– Performing Test HAVE_CXX_MSSE2 (check file: cmake/checks/cpu_sse2.cpp)
– Performing Test HAVE_CXX_MSSE2 - Success
– Performing Test HAVE_CXX_MSSE3 (check file: cmake/checks/cpu_sse3.cpp)
– Performing Test HAVE_CXX_MSSE3 - Success
– Performing Test HAVE_CXX_MSSSE3 (check file: cmake/checks/cpu_ssse3.cpp)
– Performing Test HAVE_CXX_MSSSE3 - Success
– Performing Test HAVE_CXX_MSSE4_1 (check file: cmake/checks/cpu_sse41.cpp)
– Performing Test HAVE_CXX_MSSE4_1 - Success
– Performing Test HAVE_CXX_MPOPCNT (check file: cmake/checks/cpu_popcnt.cpp)
– Performing Test HAVE_CXX_MPOPCNT - Success
– Performing Test HAVE_CXX_MSSE4_2 (check file: cmake/checks/cpu_sse42.cpp)
– Performing Test HAVE_CXX_MSSE4_2 - Success
– Performing Test HAVE_CXX_MF16C (check file: cmake/checks/cpu_fp16.cpp)
– Performing Test HAVE_CXX_MF16C - Success
– Performing Test HAVE_CXX_MFMA
– Performing Test HAVE_CXX_MFMA - Success
– Performing Test HAVE_CXX_MAVX (check file: cmake/checks/cpu_avx.cpp)
– Performing Test HAVE_CXX_MAVX - Success
– Performing Test HAVE_CXX_MAVX2 (check file: cmake/checks/cpu_avx2.cpp)
– Performing Test HAVE_CXX_MAVX2 - Success
– Performing Test HAVE_CPU_BASELINE_FLAGS
– Performing Test HAVE_CPU_BASELINE_FLAGS - Success
– Performing Test HAVE_CPU_DISPATCH_FLAGS_SSE4_1
– Performing Test HAVE_CPU_DISPATCH_FLAGS_SSE4_1 - Success
– Performing Test HAVE_CPU_DISPATCH_FLAGS_SSE4_2
– Performing Test HAVE_CPU_DISPATCH_FLAGS_SSE4_2 - Success
– Performing Test HAVE_CPU_DISPATCH_FLAGS_FP16
– Performing Test HAVE_CPU_DISPATCH_FLAGS_FP16 - Success
– Performing Test HAVE_CPU_DISPATCH_FLAGS_AVX
– Performing Test HAVE_CPU_DISPATCH_FLAGS_AVX - Success
– Performing Test HAVE_CPU_DISPATCH_FLAGS_AVX2
– Performing Test HAVE_CPU_DISPATCH_FLAGS_AVX2 - Success
– Performing Test HAVE_CXX_FVISIBILITY_HIDDEN
– Performing Test HAVE_CXX_FVISIBILITY_HIDDEN - Success
– Performing Test HAVE_C_FVISIBILITY_HIDDEN
– Performing Test HAVE_C_FVISIBILITY_HIDDEN - Success
– Performing Test HAVE_CXX_FVISIBILITY_INLINES_HIDDEN
– Performing Test HAVE_CXX_FVISIBILITY_INLINES_HIDDEN - Success
– Performing Test HAVE_C_FVISIBILITY_INLINES_HIDDEN
– Performing Test HAVE_C_FVISIBILITY_INLINES_HIDDEN - Failed
– Looking for pthread.h
– Looking for pthread.h - found
– Looking for posix_memalign
– Looking for posix_memalign - found
– Looking for malloc.h
– Looking for malloc.h - found
– Looking for memalign
– Looking for memalign - found
– Check if the system is big endian
– Searching 16 bit integer
– Looking for sys/types.h
– Looking for sys/types.h - found
– Looking for stdint.h
– Looking for stdint.h - found
– Looking for stddef.h
– Looking for stddef.h - found
– Check size of unsigned short
– Check size of unsigned short - done
– Using unsigned short
– Check if the system is big endian - little endian
– Found ZLIB: /usr/lib/x86_64-linux-gnu/libz.so (found suitable version “1.2.8”, minimum required is “1.2.3”)
– Found JPEG: /usr/lib/x86_64-linux-gnu/libjpeg.so (found version “80”)
– Found TIFF: /usr/lib/x86_64-linux-gnu/libtiff.so (found version “4.0.6”)
– Performing Test HAVE_C_WNO_UNUSED_VARIABLE
– Performing Test HAVE_C_WNO_UNUSED_VARIABLE - Success
– Performing Test HAVE_C_WNO_UNUSED_FUNCTION
– Performing Test HAVE_C_WNO_UNUSED_FUNCTION - Success
– Performing Test HAVE_C_WNO_SHADOW
– Performing Test HAVE_C_WNO_SHADOW - Success
– Performing Test HAVE_C_WNO_MAYBE_UNINITIALIZED
– Performing Test HAVE_C_WNO_MAYBE_UNINITIALIZED - Success
– Performing Test HAVE_C_WNO_MISSING_PROTOTYPES
– Performing Test HAVE_C_WNO_MISSING_PROTOTYPES - Success
– Performing Test HAVE_C_WNO_MISSING_DECLARATIONS
– Performing Test HAVE_C_WNO_MISSING_DECLARATIONS - Success
– Found Jasper: /usr/lib/x86_64-linux-gnu/libjasper.so (found version “1.900.1”)
– Found ZLIB: /usr/lib/x86_64-linux-gnu/libz.so (found version “1.2.8”)
– Found PNG: /usr/lib/x86_64-linux-gnu/libpng.so (found version “1.2.54”)
– Looking for /usr/include/libpng/png.h
– Looking for /usr/include/libpng/png.h - found
– Found OpenEXR: /usr/lib/x86_64-linux-gnu/libIlmImf.so
– Checking for module ‘gtk±3.0’
– Found gtk±3.0, version 3.18.9
– Checking for module ‘gthread-2.0’
– Found gthread-2.0, version 2.48.2
– Checking for module ‘gstreamer-base-1.0’
– Found gstreamer-base-1.0, version 1.8.3
– Checking for module ‘gstreamer-video-1.0’
– Found gstreamer-video-1.0, version 1.8.3
– Checking for module ‘gstreamer-app-1.0’
– Found gstreamer-app-1.0, version 1.8.3
– Checking for module ‘gstreamer-riff-1.0’
– Found gstreamer-riff-1.0, version 1.8.3
– Checking for module ‘gstreamer-pbutils-1.0’
– Found gstreamer-pbutils-1.0, version 1.8.3
– Checking for module ‘libdc1394-2’
– Found libdc1394-2, version 2.2.4
– Looking for linux/videodev.h
– Looking for linux/videodev.h - not found
– Looking for linux/videodev2.h
– Looking for linux/videodev2.h - found
– Looking for sys/videoio.h
– Looking for sys/videoio.h - not found
– Checking for modules ‘libavcodec;libavformat;libavutil;libswscale’
– Found libavcodec, version 56.60.100
– Found libavformat, version 56.40.101
– Found libavutil, version 54.31.100
– Found libswscale, version 3.1.101
– Checking for module ‘libavresample’
– No package ‘libavresample’ found
– Checking for module ‘libgphoto2’
– No package ‘libgphoto2’ found
– IPPICV: Download: ippicv_2017u3_lnx_intel64_general_20170822.tgz
CMake Warning at cmake/OpenCVDownload.cmake:190 (message):
IPPICV: Download failed: 1;“Unsupported protocol”
For details please refer to the download log file:
/tmp/111/opencv-3.4.0/build/CMakeDownloadLog.txt
Call Stack (most recent call first):
3rdparty/ippicv/ippicv.cmake:42 (ocv_download)
cmake/OpenCVFindIPP.cmake:243 (download_ippicv)
cmake/OpenCVFindLibsPerf.cmake:12 (include)
CMakeLists.txt:603 (include)
– Could not find OpenBLAS include. Turning OpenBLAS_FOUND off
– Could not find OpenBLAS lib. Turning OpenBLAS_FOUND off
– Could NOT find Atlas (missing: Atlas_CBLAS_INCLUDE_DIR Atlas_CLAPACK_INCLUDE_DIR Atlas_CBLAS_LIBRARY Atlas_BLAS_LIBRARY Atlas_LAPACK_LIBRARY)
– Looking for sgemm_
– Looking for sgemm_ - not found
– Performing Test CMAKE_HAVE_LIBC_PTHREAD
– Performing Test CMAKE_HAVE_LIBC_PTHREAD - Success
– Found Threads: TRUE
– Could NOT find BLAS (missing: BLAS_LIBRARIES)
– LAPACK requires BLAS
– A library with LAPACK API not found. Please specify library location.
– Could NOT find Doxygen (missing: DOXYGEN_EXECUTABLE)
– Could NOT find JNI (missing: JAVA_AWT_LIBRARY JAVA_JVM_LIBRARY JAVA_INCLUDE_PATH JAVA_INCLUDE_PATH2 JAVA_AWT_INCLUDE_PATH)
– Could NOT find Pylint (missing: PYLINT_EXECUTABLE)
– Could NOT find Matlab (missing: MATLAB_MEX_SCRIPT MATLAB_INCLUDE_DIRS MATLAB_ROOT_DIR MATLAB_LIBRARIES MATLAB_LIBRARY_DIRS MATLAB_MEXEXT MATLAB_ARCH MATLAB_BIN)
– VTK is not found. Please set -DVTK_DIR in CMake to VTK build directory, or to VTK install subdirectory with VTKConfig.cmake file
– Looking for dlerror in dl
– Looking for dlerror in dl - found
– Performing Test HAVE_C_WNO_UNDEF
– Performing Test HAVE_C_WNO_UNDEF - Success
– Performing Test HAVE_C_WNO_SIGN_COMPARE
– Performing Test HAVE_C_WNO_SIGN_COMPARE - Success
– Performing Test HAVE_CXX_WNO_DEPRECATED
– Performing Test HAVE_CXX_WNO_DEPRECATED - Success
– Performing Test HAVE_CXX_WNO_MISSING_PROTOTYPES
– Performing Test HAVE_CXX_WNO_MISSING_PROTOTYPES - Failed
– Performing Test HAVE_CXX_WNO_MISSING_DECLARATIONS
– Performing Test HAVE_CXX_WNO_MISSING_DECLARATIONS - Success
– Performing Test HAVE_CXX_WNO_SHADOW
– Performing Test HAVE_CXX_WNO_SHADOW - Success
– Performing Test HAVE_CXX_WNO_UNUSED_PARAMETER
– Performing Test HAVE_CXX_WNO_UNUSED_PARAMETER - Success
– Performing Test HAVE_CXX_WNO_UNUSED_LOCAL_TYPEDEFS
– Performing Test HAVE_CXX_WNO_UNUSED_LOCAL_TYPEDEFS - Success
– Performing Test HAVE_CXX_WNO_SIGN_COMPARE
– Performing Test HAVE_CXX_WNO_SIGN_COMPARE - Success
– Performing Test HAVE_CXX_WNO_SIGN_PROMO
– Performing Test HAVE_CXX_WNO_SIGN_PROMO - Success
– Performing Test HAVE_CXX_WNO_UNDEF
– Performing Test HAVE_CXX_WNO_UNDEF - Success
– Performing Test HAVE_CXX_WNO_TAUTOLOGICAL_UNDEFINED_COMPARE
– Performing Test HAVE_CXX_WNO_TAUTOLOGICAL_UNDEFINED_COMPARE - Failed
– Performing Test HAVE_CXX_WNO_IGNORED_QUALIFIERS
– Performing Test HAVE_CXX_WNO_IGNORED_QUALIFIERS - Success
– Performing Test HAVE_CXX_WNO_EXTRA
– Performing Test HAVE_CXX_WNO_EXTRA - Success
– Performing Test HAVE_CXX_WNO_UNUSED_FUNCTION
– Performing Test HAVE_CXX_WNO_UNUSED_FUNCTION - Success
– Performing Test HAVE_CXX_WNO_UNUSED_CONST_VARIABLE
– Performing Test HAVE_CXX_WNO_UNUSED_CONST_VARIABLE - Failed
– Performing Test HAVE_CXX_WNO_SHORTEN_64_TO_32
– Performing Test HAVE_CXX_WNO_SHORTEN_64_TO_32 - Failed
– Performing Test HAVE_CXX_WNO_DEPRECATED_DECLARATIONS
– Performing Test HAVE_CXX_WNO_DEPRECATED_DECLARATIONS - Success
CMake Error at cmake/OpenCVModule.cmake:300 (message):
No extra modules found in folder: /root/opencv_contrib/modules
Please provide path to ‘opencv_contrib/modules’ folder.
modules/CMakeLists.txt:7 (ocv_glob_modules)
– Excluding from source files list: /tmp/111/opencv-3.4.0/build/modules/imgproc/accum.neon.cpp
– Performing Test HAVE_CXX_WNO_PARENTHESES
– Performing Test HAVE_CXX_WNO_PARENTHESES - Success
– Performing Test HAVE_CXX_WNO_MAYBE_UNINITIALIZED
– Performing Test HAVE_CXX_WNO_MAYBE_UNINITIALIZED - Success
– Performing Test HAVE_CXX_WNO_ENUM_COMPARE
– Performing Test HAVE_CXX_WNO_ENUM_COMPARE - Success
– Performing Test HAVE_CXX_WNO_OVERLOADED_VIRTUAL
– Performing Test HAVE_CXX_WNO_OVERLOADED_VIRTUAL - Success
– Performing Test HAVE_CXX_WNO_UNUSED_PRIVATE_FIELD
– Performing Test HAVE_CXX_WNO_UNUSED_PRIVATE_FIELD - Failed
– DNN_FACE_DETECTOR: Download: res10_300x300_ssd_iter_140000.caffemodel
DNN_FACE_DETECTOR: Download failed: 1;“Unsupported protocol”
samples/dnn/CMakeLists.txt:20 (ocv_download)
– General configuration for OpenCV 3.4.0 =====================================
– Version control: 4.1.0-400-g1d2ef6b
– Platform:
– Timestamp: 2019-06-20T06:54:52Z
– Host: Linux 4.13.0-36-generic x86_64
– CMake: 3.15.0-rc1
– CMake generator: Unix Makefiles
– CMake build tool: /usr/bin/make
– Configuration: RELEASE
– CPU/HW features:
– Baseline: SSE SSE2 SSE3
– requested: SSE3
– Dispatched code generation: SSE4_1 SSE4_2 FP16 AVX AVX2
– requested: SSE4_1 SSE4_2 AVX FP16 AVX2
– SSE4_1 (3 files): + SSSE3 SSE4_1
– SSE4_2 (1 files): + SSSE3 SSE4_1 POPCNT SSE4_2
– FP16 (2 files): + SSSE3 SSE4_1 POPCNT SSE4_2 FP16 AVX
– AVX (5 files): + SSSE3 SSE4_1 POPCNT SSE4_2 AVX
– AVX2 (9 files): + SSSE3 SSE4_1 POPCNT SSE4_2 FP16 FMA3 AVX AVX2
– C/C++:
– Built as dynamic libs?: YES
– C++ Compiler: /usr/bin/c++ (ver 5.4.0)
– C++ flags (Release): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wno-narrowing -Wno-delete-non-virtual-dtor -Wno-comment -fdiagnostics-show-option -Wno-long-long -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -msse -msse2 -msse3 -fvisibility=hidden -fvisibility-inlines-hidden -O3 -DNDEBUG -DNDEBUG
– C++ flags (Debug): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wno-narrowing -Wno-delete-non-virtual-dtor -Wno-comment -fdiagnostics-show-option -Wno-long-long -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -msse -msse2 -msse3 -fvisibility=hidden -fvisibility-inlines-hidden -g -O0 -DDEBUG -D_DEBUG
– C Compiler: /usr/bin/cc
– C flags (Release): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-narrowing -Wno-comment -fdiagnostics-show-option -Wno-long-long -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -msse -msse2 -msse3 -fvisibility=hidden -O3 -DNDEBUG -DNDEBUG
– C flags (Debug): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-narrowing -Wno-comment -fdiagnostics-show-option -Wno-long-long -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -msse -msse2 -msse3 -fvisibility=hidden -g -O0 -DDEBUG -D_DEBUG
– Linker flags (Release):
– Linker flags (Debug):
– ccache: NO
– Precompiled headers: YES
– Extra dependencies: dl m pthread rt
– 3rdparty dependencies:
– OpenCV modules:
– To be built: calib3d core dnn features2d flann highgui imgcodecs imgproc ml objdetect photo python2 python_bindings_generator shape stitching superres ts video videoio videostab
– Disabled: js world
– Disabled by dependency: -
– Unavailable: cudaarithm cudabgsegm cudacodec cudafeatures2d cudafilters cudaimgproc cudalegacy cudaobjdetect cudaoptflow cudastereo cudawarping cudev java python3 viz
– Applications: tests perf_tests examples apps
– Documentation: NO
– Non-free algorithms: NO
– GUI:
– GTK+: YES (ver 3.18.9)
– GThread : YES (ver 2.48.2)
– GtkGlExt: NO
– VTK support: NO
– Media I/O:
– ZLib: /usr/lib/x86_64-linux-gnu/libz.so (ver 1.2.8)
– JPEG: /usr/lib/x86_64-linux-gnu/libjpeg.so (ver )
– WEBP: build (ver encoder: 0x020e)
– PNG: /usr/lib/x86_64-linux-gnu/libpng.so (ver 1.2.54)
– TIFF: /usr/lib/x86_64-linux-gnu/libtiff.so (ver 42 / 4.0.6)
– JPEG 2000: /usr/lib/x86_64-linux-gnu/libjasper.so (ver 1.900.1)
– OpenEXR: /usr/lib/x86_64-linux-gnu/libImath.so /usr/lib/x86_64-linux-gnu/libIlmImf.so /usr/lib/x86_64-linux-gnu/libIex.so /usr/lib/x86_64-linux-gnu/libHalf.so /usr/lib/x86_64-linux-gnu/libIlmThread.so (ver 2.2.0)
– Video I/O:
– DC1394: YES (ver 2.2.4)
– FFMPEG: YES
– avcodec: YES (ver 56.60.100)
– avformat: YES (ver 56.40.101)
– avutil: YES (ver 54.31.100)
– swscale: YES (ver 3.1.101)
– avresample: NO
– GStreamer:
– base: YES (ver 1.8.3)
– video: YES (ver 1.8.3)
– app: YES (ver 1.8.3)
– riff: YES (ver 1.8.3)
– pbutils: YES (ver 1.8.3)
– libv4l/libv4l2: NO
– v4l/v4l2: linux/videodev2.h
– gPhoto2: NO
– Parallel framework: pthreads
– Trace: YES (with Intel ITT)
– Other third-party libraries:
– Lapack: NO
– Eigen: NO
– Custom HAL: NO
– NVIDIA CUDA: NO
– OpenCL: YES (no extra features)
– Include path: /tmp/111/opencv-3.4.0/3rdparty/include/opencl/1.2
– Link libraries: Dynamic load
– Python 2:
– Interpreter: /usr/bin/python2.7 (ver 2.7.12)
– Libraries: /usr/lib/x86_64-linux-gnu/libpython2.7.so (ver 2.7.12)
– numpy: /usr/lib/python2.7/dist-packages/numpy/core/include (ver 1.11.0)
– packages path: lib/python2.7/dist-packages
– Python (for build): /usr/bin/python2.7
– Java:
– ant: NO
– JNI: NO
– Java wrappers: NO
– Java tests: NO
– Matlab: NO
– Install to: /usr/local
– Configuring incomplete, errors occurred!
See also “/tmp/111/opencv-3.4.0/build/CMakeFiles/CMakeOutput.log”.
See also “/tmp/111/opencv-3.4.0/build/CMakeFiles/CMakeError.log”.
root@c12f12416b0e:/tmp/111/opencv-3.4.0/build#
Do you have g++ installed? if not, please install it first, sudo apt-get install g++
then:
sudo apt-get install libv4l-dev libavresample-dev
then:
cmake -D CMAKE_BUILD_TYPE=RELEASE -D CMAKE_INSTALL_PREFIX=/usr/local
-D WITH_CUDA=on -D ENABLE_FAST_MATH=1 -D CUDA_FAST_MATH=1
-D WITH_CUBLAS=1 -D WITH_NVCUVID=on -D CUDA_GENERATION=Auto
-D WITH_OPENCL=off -D WITH_OPENCL_SVM=off -D WITH_OPENCLAMDFFT=off
-D WITH_OPENCLAMDBLAS=off
please follow the cmake command.
I was able to solve it.
Thank you very much.
How did you find a solution from the error content?
I want to refer to it when a similar error is displayed in the future.
