List of Translated Keywords
The tables below list keywords that may appear in the partition configuration file and the value allowed for each keyword.
Keywords and their values for Jetson Xavier NX and the Jetson AGX Xavier series:
Keywords and their values for Jetson TX2 series:
None for nano.
In the case of nano, how do I check it?
Thank you.
hello neuezeal,
if you had install JetPack release image via SDKmanager, you may refer to the partition layout configuration file from the release image.
for example,
$OUT/Linux_for_Tegra/bootloader/t210ref/cfg/flash_l4t_t210_emmc_p3448.xml
I checked the following command
I’m asking because the “List of Translated Keywords” section of the document doesn’t just explicitly mention jetson nano.
Thank you.
