Can the dtb built in jetpack4.6.2 and earlier versions not be applied in jetpack5.0.1?
I was using the sd card slot with good activation, but when I designate the dtb built in jetpack4.6 in jetpack5.0.1 as FDT in extlinux.conf, the screen does not appear.
I am trying to modify the kernel source of jetpack5.0.1 to activate the sdcard.
I don’t know which folder to edit the source in: galen, galen-industrial, or jakku. Can you let me know?
I think it was jakku in the previous version, but I’m confused because more has been added.
And in jetpack5.0.1, extlinux.conf contains a part that specifies dtb as FDT by default. I don’t think this was the case in the previous version, is that correct?
manager@manager-desktop:/boot/extlinux$ cat extlinux.conf
TIMEOUT 30
DEFAULT primary
MENU TITLE L4T boot options
LABEL primary
MENU LABEL primary kernel
LINUX /boot/Image
**FDT** /boot/dtb/kernel_tegra194-p3668-0001-p3509-0000.dtb
INITRD /boot/initrd
APPEND ${cbootargs} root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
The modified files and contents are as follows, and dmesg after applying dtb to the jetson emmc module is attached.
