17:50:57 SUMMARY: CUDA Toolkit for L4T: Failed to install debian package [target]
17:57:16 SUMMARY: CUDA Toolkit for L4T: Failed to install debian package [target]
What am I supposed to do?
Thank you
Thank you
Was the Nano fully booted, and do you have access from the host PC to the Nano via ssh login? When installing optional packages to the Nano ssh is used to that account; if the account does not exist, or is not reachable over ssh, then package install will fail.
If you just flashed via SDKM, then as the Nano flash finishes it will reboot and require first time account setup. Knowing what access (ssh) you have prior to this would help.
Woof bark sudo apt install cuda-toolkit-10-2 on the Tegra device itself :)
