About G-SYNC Information (Standard and Device)
Dear,
so I’d like to use G-SYNC from Jetson TX2.
So if G-SYNC standard rule is belong to opened, could you please indicate me that information.
And I’d like to know following items.
  1. Information about commercially available device which can receive G-SYNC signal. It is not limited in commercially available device, I'd like to know electrical/timing/sequence characteristcs of G-SYNC receiver interface. G-SYNC DIY kit (FullHD/4K) is available to buy or not?
regards,
Sorry I failed to post topic well.
The items should be numberd as following.
1.Information about commercially available device which can receive G-SYNC signal.
2.It is not limited in commercially available device, I’d like to know electrical/timing/sequence characteristcs of G-SYNC receiver interface.
3.G-SYNC DIY kit (FullHD/4K) is available to buy or not?
regards,
Sorry that Tegra does not support G-SYNC.
Excuse me, I can find the GSYNC signal on Jetson TX2.
SAMTEC connector A26:GSYNC_HSYNC
SAMTEC connector A27:GSYNC_VSYNC
and OEM Product design guide 7.0 DISPLAY
Are they unable to use?
Although we have hardware document pointing out Gsync, our software does not implement this function.
OK, I re-consider to use GSYNC or any other way.
Thank you very much!
