We will check this. Thanks for providing log.
Is there any update? did you reproduce the issue also?
I got one B01 sdcard board and tried the same command as yours. The device can boot up normally.
The sdcard image is made out from the Linux_for_Tegra folder downloaded by the sdkmanager.
We don’t see any issue in uboot from our side. Could you also use the driver package prepared by sdkmanager first?
Also, have you tried other sdcard?
Net: No ethernet found.
MMC: no card present
** Bad device mmc 1 **
Hit any key to stop autoboot: 0
This error from your side looks like the rootfs prepared on your sdcard image is not correct.
Thus, to verify if this is the cause, please use the driver package downaloded by sdkmnager first.
