I used my custom carrier board, the core-board is jetson nano, I used the 5G module on it, I need support some L2VPN,such as VXLAN,GREP,L2TP over it, so I need set the mtu over 1500, So How do I set jumbo frames.
You can use ip link set command to configure the jumbo frame.
Search it over the Internet shall give your the precise command.
