About Install JetPack
I’m using Jetson TX1 Development Kit(Ubuntu 16.04). I installed JetPack 2.3.1 using ‘wlan0’. Is it wrong?
I think it’s not wrong, but several folder don’t exist that write in manual, release note, read me and guide.
And I want to use on-board camera( MIPI/CSI Camera ) to Image-processing, but it has error.
Code ( This is code on Tutorial Video2) :
#include <opencv2/imgproc/imgproc.hpp>
#include <opencv2/highgui/highgui.hpp>
int main()
cv::Mat img = cv::imread(“lena.png”);
cv::Mat dst;
cv::Sobel(img, dst, CV_32F, 1, 1);
cv::imwrite("lena_sobel.png", dst);
cv::VideoCapture input(0);
// cv::VideoCapture input(“gst-launch-1.0 nvcamerasrc fpsRange=(30.0 30.0) ! ‘video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)I420, framerate=(fraction)30/1’ ! nvtee ! nvvidconv flip-method=2 ! ‘video/x-raw(memory:NVMM), format=(string)I420’ ! nvoverlaysink -e”);
for(;;)
    if (!input.read(img))
        break;
    cv::imshow("img", img);
    char c = cv::waitKey(30);
    if (c == 27)
        break;
when I use
the error is
‘HIGHGUI ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV’
when I use
there is no error, but video isn’t printed.
ubuntu@tegra-ubuntu:~/2-cv-io$ make -C build && ./build/cv_io
make: Entering directory ‘/home/ubuntu/2-cv-io/build’
make[1]: Entering directory ‘/home/ubuntu/2-cv-io/build’
make[2]: Entering directory ‘/home/ubuntu/2-cv-io/build’
Scanning dependencies of target cv_io
make[2]: Leaving directory ‘/home/ubuntu/2-cv-io/build’
[ 50%] Building CXX object CMakeFiles/cv_io.dir/io.cpp.o
[100%] Linking CXX executable cv_io
[100%] Built target cv_io
make[1]: Leaving directory ‘/home/ubuntu/2-cv-io/build’
make: Leaving directory ‘/home/ubuntu/2-cv-io/build’
Hi S_HJ,
Please follow below link steps to install JetPack:
http://docs.nvidia.com/jetpack-l4t/index.html#developertools/mobile/jetpack/l4t/2.3.1/jetpack_l4t_install.htm
I did follow that link, but I used wi-fi, not ethernet. Is this problem?
Can you see the camera preview by gstreamer? I don’t thing it about the install problem.
gst-launch-1.0 nvcamerasrc fpsRange=(30.0 30.0) ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)I420, framerate=(fraction)30/1' ! nvtee ! nvvidconv flip-method=2 ! 'video/x-raw(memory:NVMM), format=(string)I420' ! nvoverlaysink -e
