About Isaac ROS supported VGPU Environment
We continue to investigate to run Isaac ROS samples such as NVBLOX on VGPU Environment from the below post,
Our results with NVBLOX(IsaacSim4.0) Latest Examples like below;
https://nvidia-isaac-ros.github.io/concepts/scene_reconstruction/nvblox/tutorials/tutorial_isaac_sim.html
1: Vmware Horizon GPU Environment(we have both L40S and A40 GPU)-> Still same Errors.
2: AWS Environments (g4dn and g5dn) → Success to run
Question:
・ Is it OK to use IsaacROS on AWS?
(Is it tested on AWS?)
We would appreciate if you tell us the recommended VGPU environment for Isaac ROS.
Best regards,
Hi @mat-h
Thank you for your Isaac ROS utilization and your post.
Currently, Isaac ROS has not been tested on the environment you proposed, but I double-checked.
Thank you very much for your kindness.
I really appreciate your help.
We are waiting for your next feedback.
Best regards,
