About isaac sim RTX LIDAR 2D ROTARY
Important: Isaac Sim support
Note: For Isaac Sim support, the community is gradually transitioning from this forum to the Isaac Sim GitHub repository so that questions and issues can be tracked, searched, and resolved more efficiently in one place. Whenever possible, please create a GitHub Discussion or Issue there instead of starting a new forum topic.
Note: For any Isaac Lab topics, please submit your topic to its GitHub repo ( GitHub - isaac-sim/IsaacLab: Unified framework for robot learning built on NVIDIA Isaac Sim · GitHub ) following the instructions provided on Isaac Lab’s Contributing Guidelines ( Contribution Guidelines — Isaac Lab Documentation ).
6.0.0
5.1.0
5.0.0
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 24.04
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
  • Model: RTX4070S
  • Driver Version: forgot
Topic Description
i just want to ask this one. does RTX 2D ROTARY LIDAR support motion distortion??
i found the parameter named “outputMotionCompensationState” on the property tab, and it is default set to “NONECOMPENSATED”.
does it mean it is supporting motion-distortion?
it seems to be, but i want assurances.
chatgpt says it is not supported but I’m doubting it. (it says the ray fires at once. no distortion )
it will be great if i can get how RTX LIDAR works.
thank you!
Yes, the RTX 2D Rotary LiDAR does support motion distortion. Motion distortion correction is supported since Isaac Sim 5.0.
About outputMotionCompensationState:
  • NONCOMPENSATED (default) – the output point cloud contains the raw, motion-distorted data. This is what a real sensor would output.
  • COMPENSATED – the LiDAR model applies motion compensation to transform all points to a single reference frame, removing the distortion.
So if you want realistic motion-distorted LiDAR data (which is the common case for testing perception algorithms), keep the default NONCOMPENSATED setting. If you want clean, undistorted point clouds, switch to COMPENSATED.
Please check out our documentation.
Hope this clears things up!
