Hi
I want to ask if the TX1 suppert ISP function which API should I use ?LIBArgus?
And which of the samples on TX1 use ISP function?
And does nvvidconvsink in gst use ISPfunction?
Thank you
Hi
Thank you
@ymy
Any of the tegra_multimedia_api sample codes support ISP, nvvidconvsink is an independent element not relative to ISP. The nvcamerasrc is the gstreamer element for ISP support.
Check this link for more information about ISP
https://devtalk.nvidia.com/default/topic/1007117/jetson-tx1/isp-function-evaluate/post/5144806/#5144806
