When the binary built on jetson nano with jetpack4.5 installed is run on jetson nano with jetpack4.4 installed, the following error appears.
May I know what the problem is? Is backward compatibility guaranteed?
1월 20 19:51:15 manager-desktop FwJetsonAi[21762]: loading filename from:/opt/nss/ai/config_ms_coco.trt
1월 20 19:51:17 manager-desktop FwJetsonAi[21762]: [01/20/2022-19:51:17] [W] [TRT] Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
1월 20 19:51:19 manager-desktop FwJetsonAi[21762]: deserialize done
1월 20 19:51:19 manager-desktop FwJetsonAi[21762]: binding0: 4915200
1월 20 19:51:19 manager-desktop FwJetsonAi[21762]: binding1: 8568000
1월 20 19:51:19 manager-desktop FwJetsonAi[21762]: NvMMLiteOpen : Block : BlockType = 261
1월 20 19:51:19 manager-desktop FwJetsonAi[21762]: NVMEDIA: Reading vendor.tegra.display-size : status: 6
1월 20 19:51:19 manager-desktop FwJetsonAi[21762]: NvMMLiteBlockCreate : Block : BlockType = 261
1월 20 19:51:19 manager-desktop FwJetsonAi[21762]: Opening in BLOCKING MODE
1월 20 19:51:19 manager-desktop FwJetsonAi[21762]: Starting decoder capture loop thread
1월 20 19:51:19 manager-desktop FwJetsonAi[21762]: [main:FwJetsonAi.cpp(250)] [FwJetsonAi] Wait for the sigwait thread to receive SIGTERM or SIGINT
1월 20 19:51:20 manager-desktop FwJetsonAi[21762]: Video Resolution: 1920x1080
1월 20 19:51:20 manager-desktop FwJetsonAi[21762]: cuGraphicsEGLRegisterImage failed: 1, cuda process stop
1월 20 19:51:20 manager-desktop FwJetsonAi[21762]: [ERROR] (NvV4l2ElementPlane.cpp:178) <dec0> Capture Plane:Error while DQing buffer: Broken pipe
1월 20 19:51:20 manager-desktop FwJetsonAi[21762]: Error while calling dequeue at capture plane
1월 20 19:51:20 manager-desktop FwJetsonAi[21762]: Exiting decoder capture loop thread
1월 20 19:51:21 manager-desktop systemd[6249]: Starting Notification regarding a crash report...
1월 20 19:51:21 manager-desktop systemd[1]: Starting Process error reports when automatic reporting is enabled...
Thank you.
