Is it possible to use Jetson-IO tool on jetson Nano production module?
- Support for configuring for Raspberry-PI IMX219 or Raspberry-PI High Def IMX477 at run time using Jetson-IO tool on Jetson Nano 2GB, Jetson Nano and Jetson Xavier NX developer kits.
Thank you.
hello Hodu,
may I know what’s your actual use-case?
you’ll be able to apply the DTB overlay using the Jetson-IO. please also check Using the Jetson-IO Tool for reference,
thanks
I’m trying to use jetson io tool when activating my own made camera(imx327).
Thank you.
hello Hodu,
you’ll need to implement your own DTB overlay, (i.e. *.dtbo), and it’s Jetson-IO tool to load and overwrite the device tree settings to adapt your camera sensor.
Are you saying you can use jetson io tool in production module (emmc)?
Thank you.
hello Hodu,
here’s a table for Jetson-IO detects compatible hardware, Device Tree Overlays.
Jetson-IO tool is developed specifically for devkits. you should making the necessary changes to the device-tree overlays for your carrier board.
the risk is… if a user launching Jetson-IO on a customized board, it will assume that this board has the exact same headers as the devkit which is not the case and so this could mislead/confuse the user.
thanks
