Hi.
We use Jetson Nano to investigate encoder performance.
The following phenomenon has been confirmed.
a) Frame rate stabilizes with 2-stream transfer
b) Frame rate is not stable with 3-stream transfer
At the time of 3-stream transfer, Frame rate seems to be unstable due to stagnation of encoder processing.
Why does the encoder unstable behave at 3-streams?
The gstreamer pipeline at the time of confirmation is described below.
v4l2src name=cap device=/dev/video0 \
! video/x-raw,width=1920,height=1080,framerate=60/1 \
! nvvidconv name=convcap flip-method=0 output-buffers=12 \
! video/x-raw(memory:NVMM),format=(string)I420,width=1920,height=1080 \
! tee name=t \
t. \
! queue name=q0 \
! video/x-raw(memory:NVMM),framerate=60/1 \
! videorate name=fpsctl0 drop-only=true average-period=1000000000 \
! nvvidconv name=conv0 flip-method=0 output-buffers=8 \
! video/x-raw(memory:NVMM),width=1920,height=1080 \
! omxh265enc name=enc0 iframeinterval=60 bitrate=12000000 control-rate=2 vbv-size=1 EnableTwopassCBR=true EnableStringentBitrate=true insert-aud=true insert-vui=false \
! video/x-h265,stream-format=(string)byte-stream \
! rtph265pay name=pay0 pt=96 config-interval=0
! udpsink name=udp0 host=172.16.20.17 port=50000 sync=false send-duplicates=false \
t. \
! queue name=q1 \
! videorate name=fpsctl1 drop-only=true average-period=1000000000 \
! nvvidconv name=conv1 flip-method=0 output-buffers=8 \
! video/x-raw(memory:NVMM),width=1280,height=720 \
! omxh265enc name=enc1 iframeinterval=60 bitrate=6000000 control-rate=2 vbv-size=1 EnableTwopassCBR=true EnableStringentBitrate=true insert-aud=true insert-vui=false \
! rtph265pay name=pay1 pt=96 config-interval=0
! udpsink name=udp1 host=172.16.20.17 port=50002 sync=false send-duplicates=false \
t. \
! queue name=q2 \
! videorate name=fpsctl2 drop-only=true average-period=1000000000 \
! video/x-raw(memory:NVMM),framerate=30/1 \
! nvvidconv name=conv2 flip-method=0 output-buffers=8 \
! video/x-raw(memory:NVMM),width=640,height=480 \
! omxh265enc name=enc2 iframeinterval=30 bitrate=1000000 control-rate=2 vbv-size=1 EnableTwopassCBR=true EnableStringentBitrate=true insert-aud=true insert-vui=false \
! rtph265pay name=pay2 pt=96 config-interval=0
! udpsink name=udp2 host=172.16.20.17 port=50004 sync=false send-duplicates=false
