About L4T36.3 First Installation Err (some times error)
I have tested , as next command,
  1. mkdir hanwha
  2. tar xpf ./Jetson_linux_r36.3.0_aarch64.tbz2 -C hanwha/
    cd hanwha/Linux_for_Tegra/
    cd rootfs/
    sudo tar xpf …/…/…/Tegra_Linux_Sample-Root-Filesystem_R36.3.0_aarch64.tbz2
    cd …/
    sudo ./apply_binaries.sh
when i use next command:
sudo BOARDID=3767 FAB=300 BOARDSKU=0001 BOARDREV=N.2 ADDITIONAL_DTB_OVERLAY_OPT=BootOrderNvme.dtbo ./tools/kernel_flash/l4t_initrd_flash.sh --no-flash --massflash 10 --external-device nvme0n1 -c tools/kernel_flash/flash_l4t_external.xml -p “-c bootloader/generic/cfg/flash_t234_qspi.xml” --showlogs --network usb0 ai_box nvme0n1p1
the problem is
cp: cannot stat ‘signed/*’:No such file or directory
cp: cannot stat ‘signed/flash.xml.tmp’:No such file or directory
***no-flash flag enable.Exiting now…
this problem is occurred sometimes (but only happened first time installation)
first time, when i build,
do my server and Nvidia Server communicate?
yeseterday compile error is occurred
today compile error is not occurredm, now is good.
please attach full error log.
When running apply_binaries.sh, system will chroot and use apt command to install package.
i uploaded it.
sometimes error !.. i think when i first build only, it happend (in Korea)
but It happend always in America.
after compile is done, this problem is never occurred.
./bootloader/tegraparser_v2 file
When we install first-time, I think this binary file communicate to Nvidia Server.
If communication is OK, Compile is OK
If communication is NG, Compile is NG
But if compiling is done at least once, compiling is everytime OK.
please attach your full log as text file. Such screenshot has poor quality when checking.
now it is not reproduced now in my server … sorry about it.
When we install first-time, I think this binary file communicate to Nvidia Server??
using ./bootloader/tegraparser_v2 file
when i do command “./apply_binaries.sh”
it is always done (i think success)
`25/2/20 PM04:00 yesterday i execute “./apply_binaries.sh”
but
when i do command
             the result is compile err.
`25/2/21 PM04:00
i just do same command
compiling is OK.
This won’t communicate with NVIDIA server. Only apply_binaries.sh would use apt-get to install files.
Please just report issue if you could find out a method that can 100% reproduce it.
Error log is :
Please install the Secureboot package to use initrd flash for fused board
/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --no-flash --no-flash --massflash 10 --external-device nvme0n1 -c tools/kernel_flash/flash_l4t_external.xml -p -c bootloader/generic/cfg/flash_t234_qspi.xml --showlogs --network usb0 ai_box nvme0n1p1
  • Step 1: Generate flash packages *
Create folder to store images to flash
Generate image for internal storage devices
Generate images to be flashed
ADDITIONAL_DTB_OVERLAY=“BootOrderNvme.dtbo” /home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/flash.sh --no-flash --sign -c bootloader/generic/cfg/flash_t234_qspi.xml ai_box nvme0n1p1
L4T BSP Information:
R36 , REVISION: 4.3
User release: 0.0
ECID is
Board ID(3767) version(300) sku(0001) revision(N.2)
Preset RAMCODE is
Chip SKU(00:00:00:D3) ramcode() fuselevel(fuselevel_production) board_FAB(300)
emc_opt_disable_fuse:(0)
Copy /home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0001-nv.dtb to /home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0001-nv.dtb.rec
copying bctfile(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/generic/BCT/tegra234-p3767-0001-sdram-l4t.dts)… done.
copying minratchet_config(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-ratchet-p3767-0000.dts)… done.
copying device_config(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-device-p3767-0000.dts)… done.
copying misc_config(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-misc-p3767-0000.dts)… done.
copying pinmux_config(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi)… done.
copying gpioint_config(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-gpioint-p3767-0000.dts)… done.
copying pmic_config(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-pmic-p3767-0000-a02.dts)… done.
copying pmc_config(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi)… done.
copying deviceprod_config(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-cprod-p3767-0000.dts)… done.
copying prod_config(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-prod-p3767-0000.dts)… done.
copying scr_config(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb2-bct-scr-p3767-0000.dts)… done.
copying wb0sdram(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/generic/BCT/tegra234-p3767-0001-wb0sdram-l4t.dts)… done.
copying bootrom_config(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-reset-p3767-0000.dts)… done.
Existing uphylane_config(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/tegra234-mb1-bct-uphylane-si.dtsi) reused.
copying dev_params(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct-p3767-0000-l4t.dts)… done.
copying dev_params_b(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct_b-p3767-0000-l4t.dts)… done.
copying mb2bct_cfg(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb2-bct-misc-p3767-0000.dts)… done.
Existing pscfwfile(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/pscfw_t234_prod.bin) reused.
Existing pscbl1file(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/psc_bl1_t234_prod.bin) reused.
Existing mtsmcefile(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/mce_flash_o10_cr_prod.bin) reused.
Existing tscfwfile(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/tsec_t234.bin) reused.
Existing mb2applet(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/applet_t234.bin) reused.
Existing bootloader(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
copying initrd(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/l4t_initrd.img)… done.
bl is uefi
Making Boot image… done.
Not signing of boot.img
Making recovery ramdisk for recovery image…
Re-generating recovery ramdisk for recovery image…
/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/ramdisk_tmp /home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader /home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra
_BASE_KERNEL_VERSION=5.15.148-tegra
Making Recovery image…
copying recdtbfile(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0001-nv.dtb.rec)… done.
Existing sosfile(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing tegraboot(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing cpu_bootloader(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing mb2blfile(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing xusbfile(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/xusb_t234_prod.bin) reused.
Existing pvafile(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/nvpva_020.fw) reused.
Existing dcefile(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/display-t234-dce.bin) reused.
Existing nvdecfile(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/nvdec_t234_prod.fw) reused.
Existing psc_rf(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/psc_rf_t234_prod.bin) reused.
Existing mb2_rf(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/mb2rf_t234.bin) reused.
Existing mb1file(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing bpffile(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/bpmp_t234-TE980M-A1_prod.bin) reused.
copying bpfdtbfile(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/generic/tegra234-bpmp-3767-0001-3509-a02.dtb)… done.
Existing camerafw(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/camera-rtcpu-t234-rce.img) reused.
Existing apefile(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/adsp-fw.bin) reused.
Existing spefile(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/spe_t234.bin) reused.
Existing wb0boot(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/sc7_t234_prod.bin) reused.
Existing tosfile(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/tos-optee_t234.img) reused.
Existing eksfile(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/eks_t234.img) reused.
copying dtbfile(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0001-nv.dtb)… done.
Copying nv_boot_control.conf to rootfs
Skip generating system.img
Not signing of kernel-dtb
Existing tbcfile(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/uefi_jetson.bin) reused.
Existing rcm_tbcfile(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/uefi_jetson_minimal.bin) reused.
Sync’ing esp.img … done.
copying tbcdtbfile(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0001-nv.dtb)… done.
copying cfgfile(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/generic/cfg/flash_t234_qspi.xml) to flash.xml… done.
Existing flashapp(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/tegraflash.py) reused.
copying overlay_dtb(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/kernel/dtb/L4TConfiguration.dtbo)… done.
copying overlay_dtb(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/kernel/dtb/tegra234-carveouts.dtbo)… done.
copying overlay_dtb(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/kernel/dtb/tegra-optee.dtbo)… done.
copying overlay_dtb(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0000-dynamic.dtbo)… done.
copying overlay_dtb(/home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/kernel/dtb/BootOrderNvme.dtbo)… done.
./tegraflash.py --bl uefi_jetson_minimal_with_dtb.bin --odmdata gbe-uphy-config-8,hsstp-lane-map-3,hsio-uphy-config-0 --overlay_dtb L4TConfiguration.dtbo,tegra234-carveouts.dtbo,tegra-optee.dtbo,tegra234-p3768-0000+p3767-0000-dynamic.dtbo,BootOrderNvme.dtbo --bldtb tegra234-p3768-0000+p3767-0001-nv.dtb --applet mb1_t234_prod.bin --cmd “sign” --cfg flash.xml --chip “0x23” --concat_cpubl_bldtb --cpubl uefi_jetson.bin --cpubl_rcm uefi_jetson_minimal.bin --minratchet_config tegra234-mb1-bct-ratchet-p3767-0000.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --pinmux_config tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi --gpioint_config tegra234-mb1-bct-gpioint-p3767-0000.dts --pmic_config tegra234-mb1-bct-pmic-p3767-0000-a02.dts --pmc_config tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi --deviceprod_config tegra234-mb1-bct-cprod-p3767-0000.dts --prod_config tegra234-mb1-bct-prod-p3767-0000.dts --scr_config tegra234-mb2-bct-scr-p3767-0000.dts --wb0sdram_config tegra234-p3767-0001-wb0sdram-l4t.dts --br_cmd_config tegra234-mb1-bct-reset-p3767-0000.dts --uphy tegra234-mb1-bct-uphylane-si.dtsi --dev_params tegra234-br-bct-p3767-0000-l4t.dts,tegra234-br-bct_b-p3767-0000-l4t.dts --mb2bct_cfg tegra234-mb2-bct-misc-p3767-0000.dts --bins “psc_fw pscfw_t234_prod.bin; mts_mce mce_flash_o10_cr_prod.bin; tsec_fw tsec_t234.bin; mb2_applet applet_t234.bin; mb2_bootloader mb2_t234.bin; xusb_fw xusb_t234_prod.bin; pva_fw nvpva_020.fw; dce_fw display-t234-dce.bin; nvdec nvdec_t234_prod.fw; bpmp_fw bpmp_t234-TE980M-A1_prod.bin; bpmp_fw_dtb tegra234-bpmp-3767-0001-3509-a02.dtb; rce_fw camera-rtcpu-t234-rce.img; ape_fw adsp-fw.bin; spe_fw spe_t234.bin; tos tos-optee_t234.img; eks eks_t234.img” --sdram_config tegra234-p3767-0001-sdram-l4t.dts --bct_backup --boot_chain A
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0476 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0478 ] Assuming zero filled SBK key
[ 0.0466 ] Parsing partition layout
[ 0.0472 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.0506 ] Invalid partition type pva_fw
Error: Return value 4
Command tegraparser_v2 --pt flash.xml.tmp
Using bpmp-dtb concatenated with odmdata in blob for t23x
./tegraflash.py --bl uefi_jetson_minimal_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --bldtb tegra234-p3768-0000+p3767-0001-nv.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --cmd “secureflash;reboot” --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt --bins “psc_fw pscfw_t234_prod_sigheader.bin.encrypt; mts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; tsec_fw tsec_t234_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.encrypt; mb2_bootloader mb2_t234_with_mb2_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; pva_fw nvpva_020_sigheader.fw.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp_fw bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3767-0001-3509-a02_with_odm_sigheader.dtb.encrypt; rce_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt” --bct_backup
saving flash command in flashcmd.txt
*** no-flash flag enabled. Exiting now… ***
User can run above saved command in factory environment without
providing pkc and sbk keys to flash a device
Example:
$ cd bootloader
$ sudo bash ./flashcmd.txt
Error: /home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/bootloader/signed/flash.idx is not found
Error: failed to relocate images to /home/user/Documents/aibox-image-36.4.3-02212025/Linux_for_Tegra/tools/kernel_flash/images
Cleaning up…
i always use below command
and then My company use tegraparser_v2 (for Arm64)
vhw@hw-Recoder:/mnt/sdb/songholee_upgrade_for_teslar$ tree -L 4
└── Linux_for_Tegra
├── ai_box.conf (for HVC HW )
└── bootloader
    ├── LICENSE.tegraopenssl
    ├── Orin-ai_box_bsp-gpio-default.dtsi (for HVC HW )
    ├── Orin-ai_box_bsp-padvoltage-default.dtsi (for HVC HW )
    ├── Orin-ai_box_bsp-pinmux.dtsi (for HVC HW )
    ├── tegrabct_v2 (for Arm64)
    ├── tegradevflash_v2 (for Arm64)
    ├── tegrahost_v2 (for Arm64)
    ├── tegraopenssl (for Arm64)
    ├── tegraparser_v2 (for Arm64)
    ├── tegrarcm_v2 (for Arm64)
    └── tegrasign_v2 (for Arm64)
2 directories, 12 files
and then
when i do sudo command,
if server ask password to me, its ok
if server dont ask to password to me, its NG
but i used always
strong text
Hi @songho.lee
There are some points to clarify here
  1. Could you “attach” your log as a file but not just copy and paste? Your comment is hard to read because the format totally messed up.
  2. Is this a custom board made by yourself or it is from 3rdparty vendor?
  3. Why not just do a full flash first? It sounds like you just keep using no-flash command.
  4. What does that mean “for Arm64”? All of the tool provided by sdkmanager is for amd64 to run…
  5. Sorry to say that but your English comment is hard to read too. Maybe you could just put your comment in Korean and I can translate that by myself.
    answer) okay now i uploaded it.
    지금 업로드 하였다 로그 파일을 , 확인하기 바랍니다.
    v36.4.3_logs.txt (13.4 KB)
    answer) this problem is occurred on server (not board)
    it is occurred sometimes by my server (in Korea)
    it is always occurred by customer server ( in Ameria)
            이문제는 보드에서 일어나는게 아니고, 컴파일하는 서버에서 발생한다.
            한국에 내서버는 잘 발생하지 않고,
            미국의 고객의 서버에서는 항상 발생한다.
    answer) yeap it is no directly flash command using server usb
    그렇다 이코맨드는 다이렉트로 서버에서 다운로드 하는 flash 코맨드가 아니다.
             we download from cv5 board(our camera board) to nvidia orin nx using usb port
             우리회사는 CV5보드를 사용하여 Nvidia orin nx chip에 usb 포트를 통하여 다운로드 한다.
    answer) we download from cv5 board(our camera board) to nvidia orin nx using usb port
    and then we change to Arm64 file
    그래서 arm 64파일로 바꾼다.
              Arm64 files is received by nvidia.
              Arm64파일은 nvidia에서 받았다
    answer)
Could you try to use amd64 version and see if you can still reproduce this issue?
Actually this tool is not public so we may not discuss it here.
Dear Nvidia
i exatly want to know below error meanings
난 아래 에러로그들의 의미를 정확히 알고싶다.
Return value 4 : ??
question1) What does “the return value4 error” mean?
return value4 에러는 무엇을 말하는가?
Example:
$ cd bootloader
question2) What does “sudo bash ./flashcmd.txt” mean?
“sudo bash ./flashcmd.txt” 는 무엇을 의미하는가?
question3) What does “signed/flash.idx is not found” mean?
"signed/flash.idx is not found"는 정확히 무엇을 의미하는가?
It is actually not needed to explain. Based on previous experience, even knowing the meaning of “return value 4” won’t help your issue.
Also, your problem is just in the beginning of this error.
The rest of part are just the result from it. You don’t need to dig into why flash.idx is not there. Previous error already led to that result.
Please discuss your problem in the offline mail. It is not something that should be discussed in this forum.
